I am working on a script and hit a little bump. At a point I want to unlock all layers where the objects are selectable (layers unfrozen and turned on).
If I have the script initiate the layer command then there is the select options list and "u" is for unlock. It then wants a layer name or return to select items. Here is where the problem is when i'm in control I can just hit return to select the items and just select all, but when the script is running it skips my space for a return and goes to the next all statement and errors saying not a valid option. Is there a way to force that return to select the objects?
Thanks, but that unlocks all layers, but I have come to the realization that if a layer is locked and turned off then the objects will still not be selectable, so unlocking all layers will work. Thanks helping me come to that realization.
just add a little to lpseifert's code:
-layer
unlock
on
thaw
hell, if you aren't changing any of the layer properties from "-layer", when you reach the end of your script, you can just issue:
layerp
  • 3 years later...
; Andreas Behnk Juni 2012
; Klafs GmbH & CO KG
; abrufen und entsperren aller Layer einer DWG in Klassik Lisp
(defun Layer:entsperren  (/ erster zugriff layerliste i)
 (setq erster T
       i 0) ; für den ersten Layer
 (setq zugriff (tblnext "layer" erster))
 (setq layerliste (cons (cdr (assoc 2 zugriff)) layerliste))
 (setq erster NIL) ; damit werden alle anderen Layer gelesen
   (while (setq zugriff (tblnext "layer" erster))
       (setq layerliste (cons (cdr (assoc 2 zugriff)) layerliste)) ; füllt die Layer Liste
   (repeat (length layerliste)
         (command "-layer" "EN" (nth i layerliste) "")      ; entsperrt einen Layer i
     (setq  i (+ 1 i))
) ; defun
Edited by rkmcswain
added [CODE] tags
  • 2 years later...
If you are too lazy to type "-layer" command and unlock every time, then this will work.
Create a lisp file and paste this.
(defun C:LAYULKALL ()
 (command "_layer" "u" "*" "")
 (princ "\nLAYULKALL\nAll layers have been unlocked.")
(princ "\nUse LAYULKALL to unlock all layers")
Load the lisp in CAD and issue "LAYULKALL" at command line.
  • 2 months later...
Worked Perfectly
