GAH!
I am drawing a partial wall section of some open web steel joists.
I need to finish this drawing fast and I have been stuck for hours now!
So I am drawing the W-shaped webs of the steel joist section and as far as I know I am supposed to draw the webs at the correct angle (45 degrees) and then fillet them to get the radious of 30mm (Canada!).
Now whenever I fillet them they condense into the middle of the joist, and then I can't just move the arcs because then the 45 degree angle messes up.
I have probably just been staring at this too long and there is a simple solutions.
Any suggestions?
A screen shot would help,
the webs should be drawn centroidal, and then moved if req'd for fillets.
show us what you have.
ajonnason35, can you post what your have?
Welcome to the forums! Have fun, vist often!
Our neighbors to the north are always welcome!
