How can you optimize the following program? I wrote this program as a beginner, but I want the above program to be optimized without changing the performance
(defun c:line_Offset (/ pt1 pt2 pt3 pt4 ans side1 side2 offsetdist oldsnap)
  (command "textstyle" "Standard")
  (command "pdmode" 35)
  (command "pdsize" 0.015)
  (setq pt1 (getpoint "\nSpecify a location for point 1 "))
  (setq P1X (car pt1))
  (setq P1Y (cadr pt1))
  (setq P1Z (caddr pt1))
  (setq STDX (rtos P1X 2 3))
  (setq STDY (rtos P1Y 2 3))
  (setq STDZ (rtos P1Z 2 3))
  (setq COORDN (strcat "Y= " STDY))
  (setq COORDE (strcat "X= " STDX))
  (setq COORDZ (strcat "Z= " STDz))
  (setq txt (strcat COORDE " , " COORDN " , " COORDZ))
  (command "cecolor" 210)
  (command "text" "j" "bl" pt1 0.1 0 txt)
  (command "cecolor" 1)
  (command "circle" pt1 0.02)
  (command "cecolor" 255)
  (setq pt2 (getpoint "\nSpecify a location for point 2"))
  (setq P1Xx (car pt2))
  (setq P1Yy (cadr pt2))
  (setq P1Zz (caddr pt2))
  (setq STDXx (rtos P1Xx 2 3))
  (setq STDYy (rtos P1Yy 2 3))
  (setq STDZz (rtos P1Zz 2 3))
  (setq COORDNn (strcat "Y= " STDYy))
  (setq COORDEe (strcat "X= " STDXx))
  (setq COORDZz (strcat "Z= " STDzz))
  (setq txtt (strcat COORDEe " , " COORDNn " , " COORDZz))
  (command "text" "j" "bl" pt2 0.1 0 txtt)
  (command "circle" pt2 0.02)
  (command "cecolor" 92)
  (command "line" pt1 pt2 "")
    (setq pt3 (getpoint "\nSpecify Line&Offset Point "))
     (setq obj (vlax-ename->vla-object (entlast)))
     (setq pt4 (vlax-curve-getclosestpointto obj pt3))
     (command "point" pt3)
     (setq obj2 (vlax-ename->vla-object (entlast)))
     (setq side1 (rtos (distance pt1 pt4) 2 3))
     (setq side2 (rtos (distance pt4 pt2) 2 3))
     (setq offsetdist (rtos (distance pt3 pt4) 2 3))
     (setq offset (strcat "OFFSET=" offsetdist))
     (setq line (strcat "Line=" side1))
     (setq PTXT	(getpoint"Specify upper left corner:"))
     (setq THEIGHT (getreal "\nEnter Text Height:")) ;; this line added
     (command "LEADER" pt3 PTXT "" line offset "")
     (setq ELAST (entlast)) ;; this line added
     (setq OBJ (vlax-ename->vla-object ELAST)) ;; this line added
     (vlax-put-property OBJ 'Height THEIGHT) ;; this line added
;;;Whileeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
  (while
     (command "LEADER" pt3 PTXT "" line offset ""))
  ;;;WhileeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeEnddddddddddddddddddd
      (if (not AH:Butts)(load "Multi Radio buttons.lsp"))
      (if (= but nil)(setq but 1))
    (setq ans (ah:butts but "h" '("Delete lines" "Yes" "No")))
    (if (= ans "Yes")
      (vla-delete obj)
      (vla-delete obj2)))
  (setvar 'osmode oldsnap)
  (Princ)
  (c:p2pp))
I have give a code here on similar subject Line and offset
Resume your thread instead of creating a new one, because we no longer have the previous discussion to understand your train of thought...
However, by reviewing and modifying my proposed code, we could see it like this: (entmake) is more efficient than calls to (command).
Please note that the results are given in the WCS even if you are in a UCS or the entities are in a particular UCS.
(defun make_text (pt str / )
  (entmake
    (list
      '(0 . "MTEXT")
      '(100 . "AcDbEntity")
      '(100 . "AcDbMText")
      '(62 . 210)
      (if (< (car l_p) (car p3))
        (cons 71 3)
        (cons 71 1)
      (cons 10 pt)
      (cons 40 (getvar "TEXTSIZE"))
      (cons 1 str)
(defun c:line_offset ( / old_styl txt_size p1 p2 p3 p4 px dx dy l_p)
  (setq old_styl (getvar "TEXTSTYLE"))
  (setvar "TEXTSTYLE" "Standard")
  (initget 6)
  (if (setq txt_size (getdist (getvar "VIEWCTR") (strcat "\nNew textsize <" (rtos (getvar "TEXTSIZE")) ">: ")))
    (setvar "TEXTSIZE" txt_size)
  (mapcar 'setvar '("PDMODE" "PDSIZE") (list 35 (* 0.25 (getvar "TEXTSIZE"))))
  (initget 9)
  (setq p1 (trans (getpoint "\nFirst point: ") 1 0))
  (initget 9)
  (setq p2 (trans (getpoint (trans p1 0 1) "\nSecond point: ") 1 0))
  (entmake
    (list
      '(0 . "LINE")
      '(100 . "AcDbLine")
      '(62 . 3)
      (cons 10 p1)
      (cons 11 p2)
  (mapcar
    '(lambda (x) (make_text (car x) (cdr x)))
    (list
      (cons
        (polar p1 0.0 (getvar "TEXTSIZE"))
        (strcat "X: " (rtos (car p1)) "\\PY: " (rtos (cadr p1)) "\\PZ: " (rtos (caddr p1)))
      (cons
        (polar p2 0.0 (getvar "TEXTSIZE"))
        (strcat "X: " (rtos (car p2)) "\\PY: " (rtos (cadr p2)) "\\PZ: " (rtos (caddr p2)))
  (mapcar
    '(lambda (p / )
      (entmake
        (list
          '(0 . "CIRCLE")
          '(62 . 1)
          '(100 . "AcDbCircle")
          (cons 10 p)
          '(40 . 0.02)
    (list p1 p2)
  (initget 9)
  (while (setq p3 (getpoint "\nPoint to calculate?:"))
    (setq
      p3 (trans p3 1 0)
      p4 (polar p3 (+ (angle p1 p2) (* 0.5 pi)) (distance p1 p2))
      px
      (inters
        (list (car p1) (cadr p1) 0.0)
        (list (car p2) (cadr p2) 0.0)
        (list (car p3) (cadr p3) 0.0)
        (list (car p4) (cadr p4) 0.0)
        nil
    (if (not (equal (caddr p1) (caddr p2) 1E-13))
       (setq px (inters px (list (car px) (cadr px) (apply 'max (mapcar 'caddr (list p1 p2)))) p1 p2 nil))
       (setq px (list (car px) (cadr px) (caddr p1)))
    (setq
      dx (distance p1 px)
      p3 (list (car p3) (cadr p3) (caddr px))
      dy (distance px p3)
    (entmake
      (list
        '(0 . "POINT")
        '(100 . "AcDbPoint")
        '(62 . 1)
        (cons 10 p3)
    (initget 1)
    (setq
      l_p (trans (getpoint (trans p3 0 1) "\nSpecify upper left corner: ") 1 0)
      l_p (list (car l_p) (cadr l_p) (caddr px))
    (entmake
      (list
        '(0 . "LEADER")
        '(100 . "AcDbLeader")
        '(62 . 210)
        '(73 . 0)
          '(74 . 1)
          '(74 . 0)
        '(75 . 1)
        '(76 . 3)
        (cons 10 p3)
        (cons 10 l_p)
          (cons 10 (polar l_p pi (getvar "TEXTSIZE")))
          (cons 10 (polar l_p 0.0 (getvar "TEXTSIZE")))
    (mapcar
      (list
        (cons
          (polar
            (* 0.5 pi) (getvar "TEXTSIZE")
          (strcat "Line: " (rtos dx) "\\POFFSET: " (rtos dy))
  (setvar "TEXTSTYLE" old_styl)
  (prin1)
Micro seconds difference, but reduces number of variables.
  (setq COORDN (strcat "Y= " (rtos (cadr pt1) 2 3))))
  (setq COORDE (strcat "X= " (rtos (car pt1) 2 3)))
  (setq COORDZ (strcat "Z= " (rtos (caddr pt1) 2 3))))
Note a space at the end it just makes the display better when doing say getstring.
(setq PTXT	(getpoint"\nSpecify upper left corner: "))
