e.mounir Posted April 1, 2009 Posted April 1, 2009 HI, I have problem OLE link with excel sheet I take copy from excel sheet and make past special in AutoCAD. When close the cad file and open it again the I found the OLE link is not working This meaning if I edit in the excel sheet it is not update automatic And in the properties the type is static Regards Quote
mdbdesign Posted April 1, 2009 Posted April 1, 2009 I got only 2002 on front of me, but if you double-click on OLE it will open it in Excel and then you edit. Other way you need to insert spreadsheet thru... now is problem. I don't remember exact name, hope someone will help me. Quote
MaxwellEdison Posted April 1, 2009 Posted April 1, 2009 Give data links a try. I've yet to see a reason to choose OLE's over a data linke Excel table. Quote
