Jerry_VN Posted September 17, 2024 Posted September 17, 2024 (edited) Hello everyone. I have a Lisp code that works very well with Dimlinear but does not work with Dimaligned. Can anyone help me get it to work with both? Thank you very much. (defun c:Align_Dim (/ ss2ent hoanh_newerror msg init HOANH_CMD HOANH_OLDERROR *error* done cdim chanvuonggoc textdimheight phia khoangcachdim phanloai entgoc ttgoc p13goc pgoc goc heightdimgoc ssd lstd lstlevel lstam lstduong lstduongtmp pp x1 x2 index kcdimstandard kcdimht duongthu heso diemchenht pmoi *a*) ;////////////////////////////////////////////////// (defun ss2ent (ss / sodt index lstent) (setq sodt(cond (ss (sslength ss)) (t 0)) index 0) (repeat sodt (setq ent(ssname ss index) index (1+ index) lstent (cons ent lstent))) (reverse lstent)) ;////////////////////////////////////////////////// (defun hoanh_newerror (msg) (if(and (/= msg "Function cancelled") (/= msg "quit / exit abort")) (princ (strcat "\n" msg))) (done)) ;////////////////////////////////////////////////// (defun init () (setq HOANH_CMD (getvar "CMDECHO") HOANH_OLDERROR *error* *error* hoanh_newerror) (setvar "CMDECHO" 0) (command ".undo" "BE")) ;////////////////////////////////////////////////// (defun done () (command ".redraw") (command ".undo" "E") (if HOANH_CMD (setvar "CMDECHO" HOANH_CMD)) (if HOANH_OLDERROR (setq *error* HOANH_OLDERROR)) (setvar 'cmdecho 1) (princ)) ;////////////////////////////////////////////////// (defun cdim (entdt pchan pduong / tt old10 old13 old14 new10 new13 new14 p10n p13n p14n p10o p13o p14o gocduong gocchan pchanb pduongb loaidim) ;////////////////////////////////////////////////// (defun chanvuonggoc (ph p1 p2 / ptemp pkq goc) (setq goc(+ (angle p1 p2) (/ pi 2.0)) ptemp(polar ph goc 1000.0) pkq(inters ph ptemp p1 p2 nil)) pkq) ;////////////////////////////////////////////////// (setq tt(entget entdt) old10(assoc '10 tt) old13(assoc '13 tt) old14(assoc '14 tt) p10o (cdr old10) p13o (cdr old13) p14o (cdr old14) loaidim (logand (cdr (assoc '70 tt)) 7) gocduong (cond ((= loaidim 1) (angle p13o p14o)) ((= loaidim 0) (cdr (assoc '50 tt))) (t nil)) pchan(cond (pchan (list (car pchan) (cadr pchan) 0.0)) (t pchan)) pduong(cond (pduong (list (car pduong) (cadr pduong) 0.0)) (t pduong))) (if gocduong (progn(if pchan (setq pchanb (polar pchan gocduong 1000.0) p13n(chanvuonggoc (list (car p13o) (cadr p13o) 0.0) pchan pchanb) p14n(chanvuonggoc (list (car p14o) (cadr p14o) 0.0) pchan pchanb) new13(cons 13 p13n) new14(cons 14 p14n) tt(subst new13 old13 tt) tt(subst new14 old14 tt))) (if pduong (setq pduongb (polar pduong gocduong 1000.0) p10n(chanvuonggoc (list (car p10o) (cadr p10o) 0.0) pduong pduongb) new10(cons 10 p10n) tt(subst new10 old10 tt))) (entmod tt))) gocduong) ;////////////////////////////////////////////////// (defun textdimheight (ent / tmp) (command ".copy" ent "" (list 0.0 0.0 0.0) "@") (command ".explode" (entlast)) (setq tmp (cdr (assoc 40 (entget (entlast))))) (command ".erase" "p" "") tmp) ;////////////////////////////////////////////////// (defun phia (p1 p2 p3 / x1 y1 z1 x2 y2 z2 x3 y3 z3) (setq x1 (car p1) y1 (cadr p1) z1 (caddr p1) x2 (car p2) y2 (cadr p2) z2 (caddr p2) x3 (car p3) y3 (cadr p3) z3 (caddr p3) tmp (+ (* (- x1 x2) x3) (* (- y1 y2) y3) (* (- z1 z2) z3))) (cond ((= tmp 0.0) 0.0) (t (/ tmp (abs tmp))))) ;////////////////////////////////////////////////// (defun khoangcachdim (p1 ent goc / tt p2 A B D) (setq tt (entget ent) p2 (cdr (assoc 10 tt)) B (cdr (assoc 50 tt)) A (angle p1 p2) D (distance p1 p2)) (* (* D (sin (- A B))) (phia p1 (polar p1 goc 1.0) p2))) ;////////////////////////////////////////////////// (defun phanloai (ent) (setq kc(khoangcachdim pgoc ent goc) loai(fix (/ kc heightdimgoc 0.93))) (cons loai ent)) ;////////////////////////////////////////////////// (init) (while (not (setq entgoc (car (entsel "\nChon duong dim goc:"))))) (setq ttgoc(entget entgoc) p13goc(cdr (assoc 13 ttgoc)) pgoc(cdr (assoc 10 ttgoc)) goc(cdr (assoc 50 ttgoc)) heightdimgoc (textdimheight entgoc) ssd(ssget(list (cons 0 "DIMENSION") (cons -4 "<OR") (cons 70 32) (cons 70 33) (cons 70 64) (cons 70 96) (cons 70 128) (cons 70 160) (cons 70 196) (cons 70 224) (cons -4 "OR>") (cons -4 "<OR") (cons 50 goc) (cons 50 (+ goc pi)) (cons 50 (- goc pi)) (cons -4 "OR>"))) lstd(ss2ent ssd) lstd(mapcar 'phanloai lstd) lstlevel nil) (foreach pp lstd (if(not (member (car pp) lstlevel)) (setq lstlevel (append lstlevel (list (car pp)))))) (setq lstlevel(vl-sort lstlevel '(lambda (x1 x2) (< x1 x2))) lstam nil lstduong nil lstamtmp nil lstduongtmp nil) (foreach pp lstlevel (if(< pp 0.0) (setq lstam (append lstam (list pp)))) (if(> pp 0.0) (setq lstduong (append lstduong (list pp))))) (setq index 0) (foreach pp (reverse lstam) (setq index(1+ index) lstamtmp (append lstamtmp (list (cons pp index))))) (setq lstam lstamtmp index 0) (foreach pp lstduong (setq index(1+ index) lstduongtmp (append lstduongtmp (list (cons pp index))))) (setq lstduong lstduongtmp) (setq lstlevel (append lstduong lstam (list (cons 0.0 0)))) (or *a* (setq *a* (* 3.0 heightdimgoc))) ;(setq kcdimstandard (* 3.0 heightdimgoc)) (initget 6) (setq kcdimstandard (getreal(strcat "\nNhap khoang cach <" (rtos *a*) "> :"))) (if kcdimstandard (setq *a* kcdimstandard)(setq kcdimstandard *a*)) (foreach pp lstd (setq plht (car pp)) (progn (setq kcdimht(khoangcachdim pgoc (cdr pp) goc) duongthu(cdr (assoc plht lstlevel)) heso(cond ((/= 0 kcdimht) (abs (* (/ kcdimstandard kcdimht) duongthu))) (t 0.0)) diemchenht (cdr (assoc 10 (entget (cdr pp)))) pmoi(polar pgoc (angle pgoc diemchenht) (* heso (distance pgoc diemchenht)))) (cdim (cdr pp) p13goc pmoi))) (done) (princ)) Align_Dim.dwg Edited September 17, 2024 by Jerry_VN Quote
devitg Posted September 17, 2024 Posted September 17, 2024 @Jerry_VN, please show us a Before DWG Quote
Jerry_VN Posted September 18, 2024 Author Posted September 18, 2024 (edited) @devitg, Please help me data_dwg.dwg Edited September 18, 2024 by Jerry_VN Quote
Jerry_VN Posted September 24, 2024 Author Posted September 24, 2024 12 hours ago, devitg said: Please see it thank you sir ,i have fixed this error. Quote
