wakibd Posted April 2, 2009 Posted April 2, 2009 Could please anyone know how to connect/run/load this proggram with auto cad 2006 or 2008 1 using Autodesk.AutoCAD.DatabaseServices; 2 using Autodesk.AutoCAD.Runtime; 3 using System.Reflection; 4 using System.IO; 5 using System; 6 7 [assembly: SecuredApplication( 8 @"THIS IS AN OBJECTDBX VERSION 2007 CLIENT LICENSE FOR THE EXCLUSIVE USE OF Kean Walmsley. YOUR USE OF OBJECTDBX IS GOVERNED BY THE SOFTWARE LICENSE INCLUDED IN THE PRODUCT. USE OF THIS SOFTWARE IN VIOLATION OF THE SOFTWARE LICENSE IS A VIOLATION OF U.S. AND/OR INTERNATIONAL COPYRIGHT LAWS AND TREATIES AND YOU MAY BE SUBJECT TO CRIMINAL PENALTIES FOR SUCH USE.", 16 17 namespace AttributeUpdater 18 { 19 class Program 20 { 21 #region RealDWG 22 class MyHost : HostApplicationServices 23 { 24 private string SearchPath(string fileName) 25 { 26 // check if the file is already with full path 27 if (System.IO.File.Exists(fileName)) 28 return fileName; 29 30 // check application folder 31 string applicationPath = 32 Path.GetDirectoryName( 33 Assembly.GetExecutingAssembly().Location 34 ); 35 if (File.Exists(applicationPath + "\\" + fileName)) 36 return applicationPath + "\\" + fileName; 37 38 // search folders in %PATH% 39 string []paths = 40 Environment.GetEnvironmentVariable( 41 "Path").Split(new char[]{';'} 42 ); 43 foreach (string path in paths) 44 { 45 // some folders end with \\, some don't 46 string validatedPath 47 = Path.GetFullPath(path + "\\" + fileName); 48 if (File.Exists(validatedPath)) 49 return validatedPath; 50 } 51 52 // check the Fonts folders 53 string systemFonts = 54 Environment.GetEnvironmentVariable( 55 "SystemRoot" 56 ) + " Quote
