leviathin79 Posted April 4, 2009 Posted April 4, 2009 i am using the dimaligned command to apply measurements to my lines. the measurements are default at 0.0000, i only want 0.00, after i mark my line with the value, i have to then go into the properties and change the precision from 0.0000 to 0.00 is there a properties menu somewhere that i can change the default from 0.0000 to 0.00 when i double click the the value i received from one of my dimalignments it pulls up the aligned dimension properties menu, i was able to change the color of the arrows and value and even though there is a box that reads 0.0000, it wont let me change the value to 0.00 i dont have to many measurments to make so it isnt the biggest deal in the world, but if i was trying to measure out some prints i would be frustrated right now. can anyone point me in the right direction please, thanks Ken oh, and since i asked, is there a way i can get those values in fractions instead of decimals?? thanks Quote
lpseifert Posted April 4, 2009 Posted April 4, 2009 Q1. Edit the precision of your dimstyle Dimstyle > Modify > Primary Units > Precision Q2. Edit the units of your dimstyle Dimstyle > Modify > Primary Units > Unit format > Architectural Quote
Tankman Posted April 4, 2009 Posted April 4, 2009 Might "Units" on the command line also work? I set precision here to two decimal places, works for me(?). Quote
leviathin79 Posted April 4, 2009 Author Posted April 4, 2009 thanks for getting back with me, i actually got it before i came back here, still trying to figure out these menus systems. im not a fan of the command line, but i guess thats just cause i dont know the commands yet. Quote
