Hello, often in the exports of dwg from revit to Autocad, I receive files where equal symbols correspond to blocks with different names and this is certainly linked to the preparation of families etc. on Revit.
In your opinion is there a method or procedure to solve this problem directly from AutoCAD or are you (as I believe) eventually forced to replace the symbols one by one if you want to have a single block for each exported symbol?
I saw that there is a section dedicated to Revit, but I preferred to post the topic here because I would like to find a solution directly in AutoCAD
Thanks in advance for any suggestions
Hello and thank you in the meantime...
That's pretty much what I'm already doing so I'll keep going down the right path.
Greetings
