massprop
How do I use massprop command for a double hollow aluminum extrusion?
Select the item after Tools>Inquiry>Region/Mass Properties. What exactly do you need to know?
If your part is modelled as solid you can use the MASSPROP to calculate the weight. It doesn't count the shape of the solid, it can have as many holes as you wish. With the command you can find out the volume. Multiply it with the density and you have the mass.
If it is a solid the hollows should be subtracted. Perhaps you could post your DWG or a screen shot so I can see what we are talking about.
Ok, that helped. You need to make that a _Region. Make the outside portion a _Region and the inside portions _Region and _Subtract the inside Regions from the outside Region.
  • 2 years later...
