edit ground in view edit corridor sections
do u know if i i can edit the ground very fast in the view/edit sections or somewhere else??
I can do it for the assemblies but not for the ground.
Do u know if I can do it without editing the surface?
thank u
What do you mean the ground, the Existing Ground?
yes the existing ground
in ld2004 i use to edit the existing ground very fast (extend the line or cutting small anomalies that are very hard to be corrected by the surface)
I use to do it trough a table of distances and heights for every section.
in c3d i can not do it?
Hi Ikapo, I don't think you'll be able to edit the existing ground surface in the view/edit section. You'll need to edit the surface to achieve this.
