Hi all
Whenever I pres the new layer icon I get a message: a new layer was created that does not match the current layer filter.
It also gives me this message even if I change the current layer.
You will need to set the filter to ALL, or in each layer filter add LAYER*.
  • 2 months later...
Layers filters are used to see some of the layers and not others. For instance there is a filter to show layers only from XREFs. If you have one such filter active, when you create a layer it will show that message, because the layer you created is not to be shown under the current applied filter.
On the left upper side of the LAyer Manager, you can play with the different default filters or create new ones
