manchest Posted April 8, 2009 Posted April 8, 2009 Hi I am having problems with the selection windows, when I try to select items to move, delete, rotate with a left/right or right/left window, the window does not appear and therefore nothing is sellected. Is there a varible that turns this on and off? Thanks for your help Quote
lpseifert Posted April 8, 2009 Posted April 8, 2009 Options > Selection > Implied windowing maybe? Quote
ReMark Posted April 8, 2009 Posted April 8, 2009 Try setting PICKAUTO to 1 and see if that solves the problem. Quote
manchest Posted April 8, 2009 Author Posted April 8, 2009 the pickauto is already set to 1 so it not that And the implied windowing is already turn on Have you got any other ideas Thanks Quote
PS_Port Posted April 8, 2009 Posted April 8, 2009 Can you get the implied window when no command is envoked? Quote
manchest Posted April 8, 2009 Author Posted April 8, 2009 Hi again Enable grips & Noun/verb seltion are both picked The window selection does not work when I am not in a command I am going to be away for the next 5 days so I will have to get back to you next week Quote
dtkell Posted April 8, 2009 Posted April 8, 2009 Have you tried telling it to draw a window after the command and before selecting by typing "w" at the command line? Quote
tkelly Posted April 9, 2009 Posted April 9, 2009 Hi, Go to OPTIONS menu > SELECTION > VISUAL EFFECT SETTINGS Now select the desired options. Under the Selection Preview in the SELECTION tab, there are two options 1) When a command is active 2) When no command is active Select both the options. And I think your problem will be solved. Hope it helps you Tom Kelly Quote
