How do I paste to the current layer
Hello Fellow Cad Geeks,
When I copy an object and paste an object it pastes in the layer it was copied from. How do I get the object to past in my current layer?
Where are we copying from and pasting to? Within the same drawing or different drawings? Are you selecting paste or paste as block?
Hi ReMark. . .I am pasting within the same drawing. . .right on top of the object I am copying actually. I just want to paste it twice but have all three objects be in a different layer (one right on top of the other). I have figured out a few ways to do this but pasting in the current layer appears to be the fastest. . .if it can be done.
To answer your question, I am using Paste not Paste Block
Paste as block seemed to do the trick. . .everyone out there is probably saying "duh" right about now. I have no idea what that command means. . .I will do some research.
See...I knew if I hesitated just a moment you would answer your own question. Paste Block means just that. The object is treated as a block.
Hi,
you can also try using the copytolayer -command? (In the LayerII -toolbar)
Oops, if 2004 already has it?
/Petri
  • 2 years later...
"Paste Block means just that. The object is treated as a block."
yeah but as soon as you explode it, it will return to original layer , doh
edit: i found out you can use XPLODE instead of EXPLODE to specify target layer that you should, um, explode into
Paste to layer.. sounds like a useful future function for AutoCAD.
When I have to do that kind of operation, I draw a random line off in the margins somewhere, copy the items from a specific basepoint, and then copy them to the endpoint of that line.
Then switch the layer on those items using group-select and use the move command from the endpoint of that line to move the whole thing back to the basepoint I'd used earlier.
Though normally, I avoid drawing the same thing in mulitple layers by having a "sub" layer that I leave on.. while switching everything else off and on. Like drawing the footprint of a building once, on one locked layer, and then putting electrical wiring, plumbing, etc.. on seperate layers.
Normally, I call it a sub layer like "elec-sub" if it's, for example, a part of the electrical layout that remains consistant in two different electrical wiring layouts... the other layers would be "elec-1" and "elec-2".
By only having it drawn once, it's much easier to make a change to it and be sure the change is showing up everywhere, rather than risk a distraction making me forget to change an item in multiple occurances.
I do this:
COPY - pick stuff
Basepoint - 0,0
New point - 0,0
Now there are 2 on top of each other.
CHPROP
P - previous, selects the one you started with,
or L - last, the one you just created
LA - layer
Type the layer name you want it on.
