uetalic Posted April 9, 2009 Posted April 9, 2009 I have run into this problem. The 3D orbit used to work just fine but now all it does is give a pop up window below: ____________________________________________________________________________ Warning Walk and fly operations are only available when your working view is set to perspective. Toggle to a perspective view? ( ) Don't show me this message again [yes] [no] ____________________________________________________________________________ *note the ( ) is a box to check and the [yes] and [no] are button options that can be pressed.* this pop up window never occurred yesterday and I have no clue what made it start to appear when choosing the Constrained Orbit or Free Orbit from the "Orbit Window Panel Toolbar". Is there a solution to remove this pop up window? Is there a method in the system variables to reset the toggles to the Orbit commands? I tried going through HELP but I really don't know exactly what is causing this WARNING message to repeatedly pop up. The warning isn't even a proper error as ORBIT commands are being used and WALK/FLY perspective warning error pops up. Any help would be tremendous, I don't want to reinstall as a solution Quote
lt1234 Posted May 18, 2009 Posted May 18, 2009 Did you ever find a solution to this????? Thanks! Lily Quote
derrik.jenkins Posted June 10, 2009 Posted June 10, 2009 I just had this same problem occur on my CAD. I saw another thread but the suggestions were just checking your CUI. I checked and they matched the suggestion so I still don't know how to solve this problem. Please help! Quote
gbradley Posted February 11, 2010 Posted February 11, 2010 I had the same problem, Exited and Restarted MDT, no Help. Autodesk Inventor Suite 2009 Autodesk Mechanical Desktop 2009 SP3 Rebooted the computer, Restarted MDT, and problem went away. Quote
lamensterms Posted May 1, 2014 Posted May 1, 2014 Had this occur on my ACAD2012. Restarting the session fixed it, just wanted to let people know that this bug still exists. Quote
