Gin Posted April 10, 2009 Posted April 10, 2009 Greeting! I'm not really sure whether the AutoCAD having any super quick dimension tools or not. That what I'm mean was... I just need to select the object / block then it will automatic pop-out all the dimension. (Dimension show end to end of the object, radius, angle etc..) I'm seen this from 1 of my client 3 years ago and but that time I was rushing to other place that's why never ask him how he do it. Anyone has any idea on it? Thanks you. Quote
Gin Posted April 10, 2009 Author Posted April 10, 2009 Hie Cad64, Thanks for the help but not QDIM commands as you mean. For the QDIM (Quick Dimension) was just pop-out 1 dimension at 1 time. For my Super Quick Dimension was pop-out all dimension at 1 time. Example : When i select the square box it will automatic pop-out the dimension for length, width and height. ^^ Quote
Cad64 Posted April 10, 2009 Posted April 10, 2009 When i select the square box it will automatic pop-out the dimension for length, width and height. In Autocad? I've never seen such a thing. It must've been a custom command? Quote
rkent Posted April 10, 2009 Posted April 10, 2009 Hie Cad64, Thanks for the help but not QDIM commands as you mean. For the QDIM (Quick Dimension) was just pop-out 1 dimension at 1 time. For my Super Quick Dimension was pop-out all dimension at 1 time. Example : When i select the square box it will automatic pop-out the dimension for length, width and height. ^^ QDIM definitely does this for 2009 and 2010 but not for blocks, just primitives.. Quote
