Hi all,
I detail in 2D structural steel.
I am looking for a lisp that will create holes with option of offset guage line hole dia number of holes etc.
Is there anything out there or close to this?
Bill
This is a quick program. I had a better one when I detailed structural steel a couple of years ago. There is no error trapping and it can be improved. It should help you get started.
Brian
(defun c:holes ( / rows cols rowd rowv rowh hole )
 (setq rows (getint "\nEnter the number of rows (---) <1>: ")
       cols (getint "\nEnter the number of columns (|||) <1>: ")
       rowd (getdist (strcat "\nBeam guage <" (itoa 3) ">: "))
       rowv (getdist (strcat "\nVertical center / center <" (itoa 3) ">: "))
       rowh (getdist (strcat "\nHorizontal center / center <" (itoa 4) ">: "))
       hole (getdist (strcat "\nHole diameter " (rtos 0.8125) ">: "))
 (if (= rows nil)(setq rows 1))
 (if (= cols nil)(setq cols 1))
 (if (= rowd nil)(setq rowd 3))
 (if (= rowh nil)(setq rowh 4))
 (if (= rowv nil)(setq rowv 3))
 (if (= hole nil)(setq hole 0.8125))
 (setq ins (getpoint "\nSelect insertion point: "))
 (repeat cols
   (setq lstpnt (polar ins (* pi 1.5) rowd))
   (entmake (list (cons 0 "circle")(cons 10 lstpnt)(cons 40 (/ hole 2.0))))
   (repeat (1- rows)
     (setq lstpnt (polar lstpnt (* pi 1.5) rowv))
   (setq ins (polar ins 0 rowh))
Thanks brian....Hope you don't mind if I grab a copy..
nice..simple..routine..:)
Thank you for the code.
Got it to work nicely.
Now, how can I add an offset for edge distance of steel to center of first column/row hole/s?
Bill
Bill
[color=red][/color]
[color=lime]  ' Add this[/color]
[color=red]  (if (> cols 1)(setq ins (polar ins pi (/ (* (1- cols) rowh) 2.0))))[/color]
 (repeat cols
   (repeat (1- rows)
I think this might work. If it's not quite what you want send me a cad file of what you want and I will see what I can do.
Brian
Thanks Brian,
I found it not to work, yet.
What I want to be able to do is once all the input is done the last thing I need is an input of offset dist. from insertion point.
Bill Sceltema
No problems. I hope it helps.
Here is a modified version that draws end connections. I have a mutch more complete detailing program but I usually charge for that. (Sorry!)
Brian
(defun c:holes_center ( / rows cols rowd rowv rowh hole )
       rowd (getdist (strcat "\nBeam guage <" (rtos 3) ">: "))
       rowv (getdist (strcat "\nVertical center / center <" (rtos 3) ">: "))
       rowh (getdist (strcat "\nHorizontal center / center <" (rtos 4) ">: "))
 (repeat cols
   (repeat (1- rows)
(defun c:holes_end ( / dir rows rowd rowh rowv rowo hole )
 (initget 0 "Left Right")
 (setq dir  (getkword "\nEnd of beam (Left/Right) <L>: ")
       rowo (getdist (strcat "\nEndge offset <" (rtos 1.5) ">: "))
 (if (= dir  nil)(setq dir "Left"))
 (if (= rowo nil)(setq rowo 1.5))
 (if (= dir "Left")
     (setq ins (polar ins 0 rowo)
     (repeat (1- rows)
     (setq ins (polar ins pi rowo)
     (repeat (1- rows)
Thank you for the code,
I tried to add the column function as well to holes_end but I know I am missing something. Bold blue is my added code.
Am I close?
       rowd (getdist (strcat "\nBeam guage <" (rtos 30) ">: "))
       rowv (getdist (strcat "\nVertical center / center <" (rtos 30) ">: "))
       hole (getdist (strcat "\nHole diameter " (rtos 17.5) ">: "))
 (if (= rowd nil)(setq rowd 30))
 (if (= rowv nil)(setq rowv 30))
 (if (= hole nil)(setq hole 17.5))
 (repeat cols
   (repeat (1- rows)
(defun c:holes_end ( / dir rows [color=magenta][b]cols[/b][/color] rowd rowh rowv rowo hole )
[color=magenta][b]        cols (getint "\nEnter the number of columns (|||) <1>: ")[/b][/color]
       rowo (getdist (strcat "\nEndge offset <" (rtos 30) ">: "))
[b][color=magenta]  (if (= cols nil)(setq cols 1))[/color][/b]
 (if (= rowo nil)(setq rowo 30))
[color=magenta][b]  (if (> cols 1)(setq ins (polar ins pi (/ (* (1- cols) rowh) 2.0))))[/b][/color]
[b][color=magenta]  (repeat cols[/color][/b]
[b][color=magenta]    (setq lstpnt (polar ins (* pi 1.5) rowd))[/color][/b]
[b][color=magenta]    (entmake (list (cons 0 "circle")(cons 10 lstpnt)(cons 40 (/ hole 2.0))))[/color][/b]
 (if (= dir "Left")
     (repeat (1- rows)
     (repeat (1- rows)
Edited by SLW210
Try this.
Brian
(defun c:holes_end ( / cols dir rows rowd rowh rowv rowo hole )
       rowh (getdist (strcat "\nHorizontal center / center <" (rtos 3) ">: "))
 (if (= rowh nil)(setq rowh 3))
 (if (= dir "Left")
     (setq ins (polar ins 0 rowo))
     (repeat cols
       (repeat (1- rows)
     (setq ins (polar ins pi rowo))
     (repeat cols
       (repeat (1- rows)
       (setq ins (polar ins pi rowh))
Thanks Brian,
It works great.
One last request. And I understand if you say no, you've helped out alot here.
What if I wanted to instead have user input for columns they had the optionof ofset a series of columns.
I work alot with Steel angle and there are many times there is a run of holes along the length.
So a user would choose 1 or 2 rows, beam guage, hole dia., but is triggered to ask for 1st offset, 2nd offset, 3rd offset
Thanks again.
Bill
  • 1 month later...
I am attempting to add a line to your code to see if I understand the language any better.
I would like to incorporate this code into another lisp routine , but thought I would start by trying to add a simple line to your code.
Added code in bold.
(defun c:hol ( / rows cols rowd rowv rowh hole )
[b]    (setq ins (getpoint "\nInsertion Point"))
  (setq len1 (getpoint "\nLength of Line"))[/b]
(setq rows (getint "\nEnter the number of rows (---) <2>: ")
       cols (getint "\nEnter the number of columns (|||) <3>: ")
       rowv (getdist (strcat "\nVertical center / center <" (rtos 50) ">: "))
       rowh (getdist (strcat "\nHorizontal center / center <" (rtos 50) ">: "))
 (if (= rows nil)(setq rows 2))
 (if (= cols nil)(setq cols 3))
 (if (= rowd nil)(setq rowd 25))
 (if (= rowh nil)(setq rowh 50))
 (if (= rowv nil)(setq rowv 25))
[b]   (setq ins (getpoint "\nSelect insertion point: "))
 (setq pt02 (polar ins (dtr 90.0)  len1 )) [/b]
 (repeat cols
[b] (command "line" ins pt02 "") [/b]
   (repeat (1- rows)
(defun dtr (x)
(* pi (/ x 180.0))
  • 3 years later...
Mr Brian,
I have read your post that lisp for holes. I hope you only solve my problem. I want draw some circles (holes) on a line ( gauge line) on different distances. I wrote lisp for that by using your "holes Lisp". but i could not write correct. Plz rectify my lisp or give new for me. plz.........my id is ramesh22338@yahoo.com
My Lisp code :
(defun c:hh ( / rows cols rowd rowv rowh rowo hole )
(setq
cols (getint "\nEnter the number of columns (|||) : ")
rowd (getdist (strcat "\nGauge Line : "))
rowo (getdist (strcat "\n1st Hole: "))
rowh (getdist (strcat "\n2nd Hole / center : "))
rowb (getdist (strcat "\n3rd Hole / center : "))
(if (= rows nil)(setq rows 0))
(if (= rowh nil)(setq rowh 1))
(if (= rowb nil)(setq rowb 1))
(if (= rowo nil)(setq rowo 25))
(repeat cols
(repeat (1- rows)
(setq lstpntt (polar lstpnt (* pi 1.5) rowh))
(entmake (list (cons 0 "circle")(cons 10 2ndpnt)(cons 40 (/ hole 2.0))))
(setq lstpnt (polar 2ndpnt (* pi 1.5) rowb))
(entmake (list (cons 0 "circle")(cons 10 3rdpnt)(cons 40 (/ hole 2.0))))
  • 13 years later...
(defun c:HC ( / rows cols rowd rowv rowh hole )
 (repeat cols
   (repeat (1- rows)
(defun c:HE ( / dir rows rowd rowh rowv rowo hole )
 (if (= dir "Left")
     (repeat (1- rows)
     (repeat (1- rows)
Dear All,
I just need one more favour of the same holes.lsp to have place in in angle for bracings.
When I put ucs to objects place it angle, the holes going to 0,0
Please find attached lisp from this forum and resultant in image attached.
Thanks
Krishna
Edited by shortkrish
Try this change, the problem is in using entmake.
(entmake (list (cons 0 "circle")(cons 10 (trans lstpnt 1 0))(cons 40 (/ hole 2.0))))
Just a comment for multiple "please enter value" a dcl is a simpler way to go, here is an example and it has set default values as you need. You can make a dcl which also has the "Left right option as well. Just look in the top of the code attached. I use it to write the dcl then would add the left right option manually, the second step is using the RLX code to convert the dcl into lisp code so its all in one program rather than 2 files.
(setq ans (AH:getvalsm (list "Enter values " "Number rows" 5 4 "1" "Number columns " 5 4 "1" "Beamm Guage" 5 4 "3" "Vertical Cetre" 5 4 "3" "Horizontal centre" 5 4 "3" "Hole dia" 5 4 "0.8125")))
Multi GETVALS.lspConvert dcl 2 lisp rlx.lsp
