Hi I am trying to update an old lisp code
But gives me
Error: syntax error
Can any one help?
(defun c:test ( / *error* a olda dch dcl des ENT layerlist s emin1 emax1 emin2 emax2)
  ;;;List of layers
  (setq LayerList '("Layer1" "0")) ; List of layers
  (prompt "\n Select a polyline")
  (setq ENT
    (ssget (list
             (cons 0 "*POLYLINE") (cons 8 (LM:lst->str LayerList ","))
             '(-4 . "<OR") '(70 . 1) '(70 . 129) '(-4 . "OR>")
    ) ; end ssget, list
  ) ; end setq
     (setq a (vlax-curve-getarea ENT) )
  (if s
      (defun *error* ( msg )
          (if (and (= 'int (type dch)) (< 0 dch))
              (unload_dialog dch)
          (if (= 'file (type des))
              (close des)
          (if (and (= 'str (type dcl)) (findfile dcl))
              (vl-file-delete dcl)
          (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
      (cond
        (   (not
                (setq dcl (vl-filename-mktemp nil nil ".dcl")
                      des (open dcl "w")
            (princ "\nUnable to open DCL for writing.")
            (foreach str
                "ed : edit_box { alignment = left; width = 10; edit_width = 10; fixed_width = true; }"
                "anoxsymb : dialog { spacer; key = \"dcl\";"
                " : boxed_column { label = \"Option\"; height = 1.0;"
                "   : radio_button { height = 1.0; width = 20; is_tab_stop = true;"
                "     key = \"radio_button01\"; label = \"1. Option1\";"
                "   }" ; radio_button
                "     key = \"radio_button02\"; label = \"2. Option2\";"
                "   }" ; radio_button
                "   spacer;"
                "   : row { width = 22;"
                "     : ed { key = \"olda\"; label = \"Area from old drawing (m2):\"; }"
                "     : ed { key = \"a\"; label = \"Area from selected polyline (m2):\"; is_enabled = false; }"
                "   }" ; end row
                " }" ; end boxed_column
                " : boxed_column { label = \"coments......................\"; height = 1.0;"
                "   : row {"
                "     : ed { key = \"res1\"; label = \"coments......................: ±\"; is_enabled = false; }"
                "   }" ; end row
                "   : row {"
                "     : ed { key = \"res2\"; label = \"Emin:\"; is_enabled = false; }"
                "     : ed { key = \"res3\"; label = \"Emax:\"; is_enabled = false; }"
                "   }" ; end row
                " : boxed_column { label = \"coments\"; height = 1.0;"
                "   : row {"
                "     : ed { key = \"res4\"; label = \"coments:\"; is_enabled = false; edit_width = 40; }"
                "   }" ; end row
                "   spacer;"
                "   : row {"
                "     : ed { key = \"res5\"; label = \"coments......................: ±\"; is_enabled = false; }"
                "   }" ; end row
                "   : row {"
                "     : ed { key = \"res6\"; label = \"Emin:\"; is_enabled = false; }"
                "     : ed { key = \"res7\"; label = \"Emax:\"; is_enabled = false; }"
                "   }" ; end row
                "   : row {"
                "     : ed { key = \"res8\"; label = \coments:\"; is_enabled = false; edit_width = 40; }"
                "   }" ; end row
                " spacer;"
                " : row {"
                "   : column { width = 10; }" ; end column
                "   : column { width = 17;"
                "     : button { key = \"cal\"; label = \"Calculation\"; is_default = true; is_cancel = false; fixed_width = true; width = 10; }"
                "   }" ; end column
                "     : button { key = \"OK\"; label = \"OK\"; is_default = true; is_cancel = true; fixed_width = true; width = 10; }"
                "   }" ; end column
                " }" ; end row
                "}" ; end dialog
              (write-line str des)
            (setq des (close des)
                  dch (load_dialog dcl)
            (<= dch 0)
            (princ "\nUnable to load DCL file.")
        (   (not (new_dialog "anoxsymb" dch))
            (princ "\nUnable to display 'anoxsymb' dialog.")
        (t
            (set_tile "dcl" "coments......................")
            (action_tile "a" "(setq a $value)")
            (action_tile "cal"
                (vl-prin1-to-string
                    (quote
					   (set_tile "a" "")
                            (set_tile "res1" "")
                            (set_tile "res2" "")
                            (set_tile "res3" "")
                            (set_tile "res4" "")
                            (set_tile "res5" "")
                            (set_tile "res6" "")
                            (set_tile "res7" "")
                            (set_tile "res8" "")
                                (cond
                                    ((= (get_tile "radio_button01") "1") ; 1. Option1
                                            (setq anox (* olda 0.05)
                                                  efor (* olda 0.02)
                                                  emin1 (- olda anox)
                                                  emax1 (+ olda anox)
                                                  emin2 (- olda efor)
                                                  emax2 (+ olda efor)
                                        (mode_tile "a" 2)
                                        (set_tile "a" (rtos a 2 2))
                                        (set_tile "res1" (rtos anox 2 2))
                                        (set_tile "res2" (rtos emin1 2 2))
                                        (set_tile "res3" (rtos emax1 2 2))
                                        (set_tile "res4"
                                          (cond
                                            ((<= emin1 a emax1) "coments...................... 5%.")
                                            ((> emin1 a) "coments......................")
                                            ((< emax1 a) "coments......................")
                                        (set_tile "res5" (rtos efor 2 2))
                                        (set_tile "res6" (rtos emin2 2 2))
                                        (set_tile "res7" (rtos emax2 2 2))
                                        (set_tile "res8"
                                          (cond
                                            ((<= emin2 a emax2) "coments......................2%.")
                                            ((> emin2 a) "coments......................")
                                            ((< emax2 a) "coments......................")
                                    ((= (get_tile "radio_button02") "1") ; 2. Option2
                                            (setq anox (* olda 0.10)
                                                  efor (* olda 0.02)
                                                  emin1 (- olda anox)
                                                  emax1 (+ olda anox)
                                                  emin2 (- olda efor)
                                                  emax2 (+ olda efor)
                                        (mode_tile "a" 2)
                                        (set_tile "res4"
                                          (cond
                                            ((<= emin1 a emax1) "coments......................10%.")
                                        (set_tile "res8"
                                          (cond
                                            ((<= emin2 a emax2) "coments...................... 2%.")
                                ) ; end cond
            (start_dialog)
    (*error* nil)
) ; end defun
Error: syntax error
Thanks
Here, I cleaned your code again... There was small error in DCL which I fixed and added setting "olda" = "a" variable at the beginning of lisp... I don't know what do you do with all this, but I made sure it works... Now rest of fine tunning I leave to you...
(defun c:test ( / *error* LM:lst->str a olda dch dcl des ent layerlist s anox efor emin1 emax1 emin2 emax2 )
    (if (and (= (quote int) (type dch)) (< 0 dch))
      (unload_dialog dch)
    (if (= (quote file) (type des))
      (close des)
    (if (and (= (quote str) (type dcl)) (findfile dcl))
  (defun LM:lst->str ( lst del )
    (if (cdr lst)
      (strcat (car lst) del (LM:lst->str (cdr lst) del))
      (car lst)
  ;;;List of layers
  (setq LayerList (list "Layer1" "0"))
  (prompt "\nPick a closed polyline...")
  (setq s
    (ssget "_+.:E:S"
      (list
        '(-4 . "<OR") '(70 . 1) '(70 . 3) '(-4 . "<AND") '(70 . 5) '(75 . 5) '(-4 . "AND>") '(-4 . "<AND") '(70 . 5) '(75 . 6) '(-4 . "AND>") '(70 . 129) '(-4 . "<AND") '(70 . 131) '(75 . 0) '(-4 . "AND>") '(-4 . "<AND") '(70 . 131) '(75 . 5) '(-4 . "AND>") '(-4 . "<AND") '(70 . 133) '(75 . 5) '(-4 . "AND>") '(-4 . "<AND") '(70 . 133) '(75 . 6) '(-4 . "AND>") '(-4 . "OR>")
  (setq a (vlax-curve-getarea (setq ent (ssname s 0))))
  (setq olda a) ;;; Added this line as dialog box won't perform calculation without setting variable "olda" ; mod. by M.R. ;;;
  (if ent
      (cond
        ( (not
                  des (open dcl "w")
            (foreach str
                "   }" ; radio_button
                "   }" ; radio_button
                "   spacer;"
                "   }" ; end row
                "   : row {"
                "   }" ; end row
                "   : row {"
                "   }" ; end row
                "   : row {"
                "   }" ; end row
                "   spacer;"
                "   : row {"
                "   }" ; end row
                "   : row {"
                "   }" ; end row
                "   : row {"
                "     : ed { key = \"res8\"; label = \"coments:\"; is_enabled = false; edit_width = 40; }"
                "   }" ; end row
                " spacer;"
                " : row {"
                "   }" ; end column
                "   }" ; end column
                " }" ; end row
                "}" ; end dialog
            (<= dch 0)
        ( t
          (action_tile "cal"
            (vl-prin1-to-string
              (quote
                  (set_tile "a" "")
                  (cond
                    ( (= (get_tile "radio_button01") "1") ; 1. Option1
                            efor (* olda 0.02)
                            emin1 (- olda anox)
                            emax1 (+ olda anox)
                            emin2 (- olda efor)
                            emax2 (+ olda efor)
                      (mode_tile "a" 2)
                      (set_tile "a" (if (= (type a) (quote real)) (rtos a 2 4) (rtos (atof a) 2 4)))
                      (set_tile "res4"
                        (cond
                          ( (<= emin1 (if (= (type a) (quote str)) (atof a) a) emax1)
                          ( (> emin1 (if (= (type a) (quote str)) (atof a) a))
                          ( (< emax1 (if (= (type a) (quote str)) (atof a) a))
                      (set_tile "res8"
                        (cond
                          ( (<= emin2 (if (= (type a) (quote str)) (atof a) a) emax2)
                          ( (> emin2 (if (= (type a) (quote str)) (atof a) a))
                          ( (< emax2 (if (= (type a) (quote str)) (atof a) a))
                    ( (= (get_tile "radio_button02") "1") ; 2. Option2
                            efor (* olda 0.02)
                            emin1 (- olda anox)
                            emax1 (+ olda anox)
                            emin2 (- olda efor)
                            emax2 (+ olda efor)
                      (mode_tile "a" 2)
                      (set_tile "res4"
                        (cond
                      (set_tile "res8"
                        (cond
      (start_dialog)
  (*error* nil)
HTH.
Regards, M.R.
Edited by marko_ribar
haha Marko just beat me to it... awell , here's my code anyway but there where many , too many mistakes in OP's code , sloppy...
(defun c:test ( / *error* ss a olda dch dcl des ENT layerlist s emin1 emax1 emin2 emax2)
  ;; List to String  -  Lee Mac
;; Concatenates each string in a supplied list, separated by a given delimiter
;; lst - [lst] List of strings to concatenate
;; del - [str] Delimiter string to separate each item
  (defun LM:lst->str ( lst del / str )
    (setq str (car lst)) (foreach itm (cdr lst) (setq str (strcat str del itm)))
    str
    (if (and (= 'int (type dch)) (< 0 dch))(unload_dialog dch))
    (if (= 'file (type des))(close des))
    (if (and (= 'str (type dcl)) (findfile dcl))(vl-file-delete dcl))
      (princ (strcat "\nError: " msg)))
  ;;;List of layers
  (if (and (setq ss (ssget (list (cons 0 "*POLYLINE")
              (cons 8 (LM:lst->str LayerList ",")) '(-4 . "<OR") '(70 . 1) '(70 . 129) '(-4 . "OR>"))))
           (setq a (vlax-curve-getarea (ssname ss 0))) (setq olda a))
      (if (not (and (setq dcl (vl-filename-mktemp nil nil ".dcl")) (setq des (open dcl "w"))))
        (alert "Unable to open DCL for writing")
          (foreach str
                "   }" ; radio_button
                "   }" ; radio_button
                "   spacer;"
                "   }" ; end row
                "   : row {"
                "   }" ; end row
                "   : row {"
                "   }" ; end row
                "   : row {"
                "   }" ; end row
                "   spacer;"
                "   : row {"
                "   }" ; end row
                "   : row {"
                "   }" ; end row
                "   : row {"
                "     : ed {key = \"res8\"; label = \"Comments\"; is_enabled = false; edit_width = 40; }"
                "   }" ; end row
                " spacer;"
                " : row {"
                "     : button {key=\"cal\";label=\"Calculation\";is_default=true;is_cancel=false;fixed_width=true;width=10;}"
                "   }" ; end column
                "     : button {key=\"OK\";label=\"OK\";is_default=true;is_cancel=true;fixed_width=true;width=10;}"
                "   }" ; end column
                " }" ; end row
                "}" ; end dialog
          (setq des (close des) dch (load_dialog dcl))
      (cond
        ((<= dch 0) (princ "\nUnable to load DCL file."))
        ((not (new_dialog "anoxsymb" dch)) (princ "\nUnable to display 'anoxsymb' dialog."))
        (t
         (action_tile "OK" "(done_dialog)")
         (action_tile "cal" "(CountCalcula)")
         (start_dialog)
  (setq *error* nil)
) ; end defun
(defun CountCalcula ()
  (set_tile "a" "")
  (set_tile "res1" "")(set_tile "res2" "")(set_tile "res3" "")(set_tile "res4" "")
  (set_tile "res5" "")(set_tile "res6" "")(set_tile "res7" "")(set_tile "res8" "")
  (cond
    ;;; 1. Option1
     (setq anox (* olda 0.05) efor (* olda 0.02)
           emin1 (- olda anox) emax1 (+ olda anox)
           emin2 (- olda efor) emax2 (+ olda efor))
     (mode_tile "a" 2)
     (set_tile "a" (rtos a 2 2)) (set_tile "res1" (rtos anox 2 2)) (set_tile "res2" (rtos emin1 2 2))
     (set_tile "res4"
       (cond
     (set_tile "res8"
       (cond
    ;;; 2. Option2
     (setq anox (* olda 0.10) efor (* olda 0.02)
     (mode_tile "a" 2)
     (set_tile "res4"
       (cond
     (set_tile "res8"
       (cond
  ) ; end cond
Edited by rlx
Hi , Thanks for the help. rlx I test your code but the calculations is wrong in this  part anox (* olda 0.05) is correct but in the result give me this  anox (* a 0.05)
Can you fix it?
Thanks
I find it . I add
    (cond
          ((not (setq olda (distof (get_tile "olda"))))
          (setq len 0.0)
;.............. rest of the code
I want to ask something else.  I make this box biger.
 "     : ed {key = \"res8\"; label = \"Comment:\"; is_enabled = false; edit_width = 60; height = 4.0; }"
I have a big comment to insert
         ((> emin1 a) "coments..................................................................................................................")
         ((< emax1 a) "coments..................................................................................................................")
         ((> emin2 a) "coments...................................................................................................................")
         ((< emax2 a) "coments...................................................................................................................")
Is any way to warp the insert comment in the box?
Thanks
maybe create a second pre-defined edit box like you did for "ed : edit_box { alignment = left; width = 10; edit_width = 10; fixed_width = true; }"
but now call it "ed100 : edit_box {fixed_width=true;width=100; edit_width=100;}"
ps you don't need the alignment part for edit boxes , as far as I know  they are always left aligned.
Edited by rlx
I find this way . I divide the text to tree parts. I don't know if it is any other better way !!!
 " : boxed_column { label = \"comment\"; height = 1.0;"
                "   : row {"
                "     : ed { key = \"res4_1\"; label = \"             \"; is_enabled = false; edit_width = 80;}"
                "   }" ; end row
                "   : row {"
                "     : ed { key = \"res4_2\"; label = \"             \"; is_enabled = false; edit_width = 80;}"
                "   }" ; end row
                "   : row {"
                "     : ed { key = \"res4_3\"; label = \"             \"; is_enabled = false; edit_width = 80;}"
                "   }" ; end row
     (set_tile "res4_1"
       (cond
         ((<= emin1 a emax1) " ....................................................")
         ((> emin1 a) " ....................................................")
         ((< emax1 a) " ....................................................")
     (set_tile "res4_2"
       (cond
     (set_tile "res4_3"
       (cond
Thanks
if it works for you it works, some forms of coding can sometimes better and some forms are just ego tripping 😄
now its bed time for me , early bird tomorrow (5.30 am) 🛌 😴 💤
