Lee Mac Posted November 21, 2024 Author Posted November 21, 2024 Thank you for your compliments & positive feedback, I'm glad you find my programs useful For your request, the following alternative should get you most of the way there: https://www.cadtutor.net/forum/topic/50509-manipulating-with-text-numbers/#comment-419766 Quote
mohammadreza Posted June 2, 2025 Posted June 2, 2025 On 4/12/2009 at 11:37 PM, Lee Mac said: Hi Guys, Wasn't that busy, so I thought I'd put together a little Incremental Numbering Suite for you all to sample. I've come to realise that this kind of LISP seems to be quite a popular one in many trades, and this was my main inspiration for its creation. As with all my programs - your comments and/or criticism is welcome, as this only helps to improve the program itself. Thanks & Enjoy! Cheers Lee Incremental Numbering Suite Main Dialog Preview: http://lee-mac.com/lisp/gifs/NumIncV3-3.png About Dialog Preview: http://lee-mac.com/lisp/gifs/NumIncV3-3A.png Incrementing two sections of Text with a Background Mask and Rectangular Border: http://lee-mac.com/lisp/gifs/NumInc0.gif Incrementing with Leading Zeros: http://lee-mac.com/lisp/gifs/NumInc1.gif Text with a Slot Border: http://lee-mac.com/lisp/gifs/NumInc2.gif Placing text in a Table Cell: http://lee-mac.com/lisp/gifs/NumInc3.gif Incrementing Text with Leading Zeros and Hexagonal Border: http://lee-mac.com/lisp/gifs/NumInc4.gif Incrementing alpha text, demonstrating rotation of Triangular Border: http://lee-mac.com/lisp/gifs/NumInc5.gif Curve-Aligned Mode: http://lee-mac.com/lisp/gifs/NumIncC.gif Array Example 1 Demonstrating the difference between Spacing Vector and Endpoint specification, with Object Rotation set to 'Aligned'. http://lee-mac.com/lisp/gifs/NumIncA1.gif Array Example 2 Demonstrating Perpendicular rotation and a fixed zero rotation. http://lee-mac.com/lisp/gifs/NumIncA2.gif A full description of the program and the latest version can be found here. NumIncV3-9.zip 31.99 kB · 162 downloads hi bro i tried to use that part of your code (img20b) , but failed . can you help me ? i need that pic on button. this is my code. (vl-load-com) (defun draw_txt_pik_image () (setq pixels '( -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 095 096 096 096 096 096 096 096 096 095 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 096 254 254 254 254 254 254 254 254 096 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 096 063 063 -15 063 063 063 063 063 096 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 096 063 -15 250 -15 063 063 063 063 096 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 096 -15 250 250 -15 063 063 063 063 096 -15 -15 -15 -15 -15 -15 -15 -15 -15 -15 254 250 -15 250 -15 063 063 063 063 096 -15 -15 -15 -15 254 254 254 254 254 254 250 -15 -15 250 -15 063 063 063 063 096 254 254 254 254 254 254 254 254 254 250 -15 -15 -15 250 -15 063 063 063 063 096 254 254 254 254 254 254 254 254 250 -15 -15 -15 -15 250 -15 063 063 063 063 096 254 254 254 254 254 254 254 250 250 250 -15 -15 -15 250 -15 063 063 063 063 096 254 254 254 254 254 254 254 254 254 250 -15 250 -15 250 -15 063 063 063 063 096 254 254 254 254 254 254 254 254 254 250 -15 250 250 250 -15 063 063 063 063 096 254 254 254 254 254 254 254 254 250 -15 250 254 254 250 254 096 096 096 096 095 254 254 254 254 254 254 254 254 250 -15 250 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 250 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 -15 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 254 -15 ) ) (setq x nil y nil) (repeat 20 (repeat 20 (setq x (cons (length x) x)))) (setq y (reverse x)) (start_image "txt-pik") (fill_image 0 0 20 20 -15) (mapcar 'vector_image x y x y pixels) (end_image) ) (defun pick-text-height-with-mouse ( / pt1 pt2 ) (setq pt1 (getpoint "\nSelect first point for text height: ")) (if pt1 (progn (setq pt2 (getpoint pt1 "\nSelect second point: ")) (if pt2 (distance pt1 pt2) nil ) ) nil ) ) (defun hatch-circle-by-layer (layer-name color / ss i ent doc space hatch loopArray) (if (layer-exists-p layer-name) (progn (setq ss (ssget "X" (list '(0 . "CIRCLE") (cons 8 layer-name)))) (if ss (progn (setq doc (vla-get-ActiveDocument (vlax-get-Acad-Object))) (setq space (if (= (getvar "CVPORT") 1) (vla-get-PaperSpace doc) (vla-get-ModelSpace doc) ) ) (setq i 0) (while (< i (sslength ss)) (setq ent (vlax-ename->vla-object (ssname ss i))) (setq hatch (vla-AddHatch space acHatchPatternTypePreDefined "SOLID" :vlax-true ) ) (setq loopArray (vlax-make-safearray vlax-vbObject '(0 . 0))) (vlax-safearray-put-element loopArray 0 ent) (vla-AppendOuterLoop hatch loopArray) (vla-Evaluate hatch) (vla-put-Layer hatch layer-name) (vla-put-Color hatch color) (setq i (1+ i)) ) ) ) ) ) ) (defun insert-field-values (name father_name personal_code address company_name boss_name melli_code shomare_parvaneh shomare_sabt address_mojri tedade_tabaghat tedade_vahed tabaghe_vahed jahate_vahed txt_size build_val plumb_val coat_val standard_val sealing_val / blk ent att tag ) (setq blk (entnext)) (while blk (if (= (cdr (assoc 0 (entget blk))) "INSERT") (progn (setq ent (entnext blk)) (while (and ent (/= (cdr (assoc 0 (entget ent))) "SEQEND")) (setq att (entget ent)) (if (= (cdr (assoc 0 att)) "ATTRIB") (progn (setq tag (strcase (cdr (assoc 2 att)))) (cond ((= tag "NAME") (entmod (subst (cons 1 name) (assoc 1 att) att)) ) ((= tag "FATHER_NAME") (entmod (subst (cons 1 father_name) (assoc 1 att) att)) ) ((= tag "PERSONAL_CODE") (entmod (subst (cons 1 personal_code) (assoc 1 att) att)) ) ((= tag "ADDRESS") (entmod (subst (cons 1 address) (assoc 1 att) att)) ) ((= tag "COMPANY_NAME") (entmod (subst (cons 1 company_name) (assoc 1 att) att)) ) ((= tag "BOSS_NAME") (entmod (subst (cons 1 boss_name) (assoc 1 att) att)) ) ((= tag "MELLI_CODE") (entmod (subst (cons 1 melli_code) (assoc 1 att) att)) ) ((= tag "SHOMARE_PARVANEH") (entmod (subst (cons 1 shomare_parvaneh) (assoc 1 att) att)) ) ((= tag "SHOMARE_SABT") (entmod (subst (cons 1 shomare_sabt) (assoc 1 att) att)) ) ((= tag "ADDRESS_MOJRI") (entmod (subst (cons 1 address_mojri) (assoc 1 att) att)) ) ((= tag "TEDADE_TABAGHAT") (entmod (subst (cons 1 tedade_tabaghat) (assoc 1 att) att)) ) ((= tag "TEDADE_VAHED") (entmod (subst (cons 1 tedade_vahed) (assoc 1 att) att)) ) ((= tag "TABAGHE_VAHED") (entmod (subst (cons 1 tabaghe_vahed) (assoc 1 att) att)) ) ((= tag "JAHATE_VAHED") (entmod (subst (cons 1 jahate_vahed) (assoc 1 att) att)) ) ) ) ) (setq ent (entnext ent)) ) ) ) (setq blk (entnext blk)) ) ) (defun c:a (/ dcl_id result name father_name personal_code address company_name boss_name melli_code shomare_parvaneh shomare_sabt address_mojri tedade_tabaghat tedade_vahed tabaghe_vahed jahate_vahed build_val plumb_val coat_val standard_val sealing_val *hatch-color* picked-height picked-from-mouse) ;;; (setq txt_size "2.5") ; always reset ;;;(draw_txt_pik_image) (or *hatch-color* (setq *hatch-color* 1)) (setq dcl_id (load_dialog "project_input.dcl")) (if (not (new_dialog "field_dialog" dcl_id)) (progn (alert "Cannot load dialog file.") (exit)) ) (draw_txt_pik_image) ;; apply default txt_size only if not picked by mouse (if txt_size (set_tile "txt_size" txt_size)) ;; radio button defaults (set_tile "building_type" "commercial") (set_tile "plumbing_type" "both") (set_tile "coating_type" "both2") (set_tile "standard" "ISIRI") (set_tile "sealing_type" "standard_sealing") ;; color preview function (defun update_color_preview () (start_image "color_preview") (fill_image 0 0 (dimx_tile "color_preview") (dimy_tile "color_preview") *hatch-color*) (end_image) ) (update_color_preview) ;; color buttons (action_tile "color_btn" "(progn (setq *hatch-color* (acad_colordlg *hatch-color*)) (update_color_preview))") (action_tile "color_preview" "(progn (setq *hatch-color* (acad_colordlg *hatch-color*)) (update_color_preview))") ;; accept inputs (action_tile "accept" (strcat "(progn " "(setq name (get_tile \"name\")) " "(setq father_name (get_tile \"father_name\")) " "(setq personal_code (get_tile \"personal_code\")) " "(setq address (get_tile \"address\")) " "(setq company_name (get_tile \"company_name\")) " "(setq boss_name (get_tile \"boss_name\")) " "(setq melli_code (get_tile \"melli_code\")) " "(setq shomare_parvaneh (get_tile \"shomare_parvaneh\")) " "(setq shomare_sabt (get_tile \"shomare_sabt\")) " "(setq address_mojri (get_tile \"address_mojri\")) " "(setq tedade_tabaghat (get_tile \"tedade_tabaghat\")) " "(setq tedade_vahed (get_tile \"tedade_vahed\")) " "(setq tabaghe_vahed (get_tile \"tabaghe_vahed\")) " "(setq jahate_vahed (get_tile \"jahate_vahed\")) " "(setq txt_size (get_tile \"txt_size\")) " "(setq build_val (get_tile \"building_type\")) " "(setq plumb_val (get_tile \"plumbing_type\")) " "(setq coat_val (get_tile \"coating_type\")) " "(setq standard_val (get_tile \"standard\")) " "(setq sealing_val (get_tile \"sealing_type\")) " "(done_dialog 1))" ) ) ;; cancel (action_tile "cancel" "(done_dialog 0)") ;; image button: pick text height (action_tile "txt-pik" "(done_dialog 2)") ;; show dialog (setq result (start_dialog)) (unload_dialog dcl_id) (cond ;; accept ((= result 1) ;; reset flag (setq picked-from-mouse nil) (insert-field-values name father_name personal_code address company_name boss_name melli_code shomare_parvaneh shomare_sabt address_mojri tedade_tabaghat tedade_vahed tabaghe_vahed jahate_vahed txt_size build_val plumb_val coat_val standard_val sealing_val ) (delete-hatch-by-layer '("circle_residential" "circle_commercial" "circle_educational" "circle_public" "circle_API" "circle_DIN" "circle_gas_tight" "circle_religious" "circle_industrial" "circle_concealed" "circle_ISIRI" "circle_PAINTING" "circle_STANDARD_SEALING" "circle_wrapping" "circle_exposed" "circle_both" "circle_both2") ) (if build_val (hatch-circle-by-layer (strcat "circle_" build_val) *hatch-color*)) (if plumb_val (hatch-circle-by-layer (strcat "circle_" plumb_val) *hatch-color*)) (if coat_val (hatch-circle-by-layer (strcat "circle_" coat_val) *hatch-color*)) (if standard_val (hatch-circle-by-layer (strcat "circle_" standard_val) *hatch-color*)) (if sealing_val (hatch-circle-by-layer (strcat "circle_" sealing_val) *hatch-color*)) (princ "\nAll operations completed successfully.") ) ;; pick height ((= result 2) (setq picked-height (pick-text-height-with-mouse)) (if picked-height (progn (setq txt_size (rtos picked-height 2 2)) ) ) (c:a) ) ) (princ) ) (defun delete-hatch-by-layer (layers / ss i e) (foreach lay layers (if (layer-exists-p lay) (progn (setq ss (ssget "X" (list '(0 . "HATCH") (cons 8 lay)))) (if ss (progn (setq i 0) (while (< i (sslength ss)) (setq e (ssname ss i)) (entdel e) (setq i (1+ i)) ) ) ) ) ) ) ) (defun layer-exists-p (layerName) (tblsearch "LAYER" layerName) ) (princ) Quote
Lee Mac Posted June 2, 2025 Author Posted June 2, 2025 Does your DCL file define the appropriate image_button tile with key "txt-pik". Quote
mohammadreza Posted June 2, 2025 Posted June 2, 2025 2 hours ago, Lee Mac said: Does your DCL file define the appropriate image_button tile with key "txt-pik". field_dialog : dialog { label = "Project Information Input"; spacer; : row { alignment = centered; fixed_width = false; children_alignment = top; : boxed_radio_column{ fixed_height = true; label = "äæÚ áæáå˜Ôí:"; key = "plumbing_type"; : radio_button { label = "Êæí ˜ÇÑ"; key = "concealed"; } : radio_button { label = "Ñæí ˜ÇÑ"; key = "exposed"; } : radio_button { label = "åÑÏæ"; key = "both"; } } : boxed_radio_column {fixed_height = true; label = "äæÚ æÔÔ:"; key = "coating_type"; : radio_button { label = "Ñä ÂãíÒí"; key = "painting"; } : radio_button { label = "äæÇÑíí"; key = "wrapping"; } : radio_button { label = "åÑÏæ"; key = "both2"; } } : boxed_radio_column {fixed_height = true; label = "ÇÓÊÇäÏÇÑÏ:"; key = "standard"; : radio_button { label = "ISIRI 3360"; key = "ISIRI"; } : radio_button { label = "API 5L"; key = "API"; } : radio_button { label = "DIN 2440"; key = "DIN"; } } : boxed_radio_column {fixed_height = true; height = 5.8; label = "äæÚ ÏÑÒÈäÏí:"; key = "sealing_type"; : radio_button { label = "ãÚãæáí"; key = "standard_sealing"; } : radio_button { label = "åæÇÈäÏ"; key = "gas_tight"; } } : boxed_column { children_alignment = centered; height = 5.8;width = 2; fixed_width=true; fixed_height=true; label = "åÇÔæÑ"; : row { fixed_height=true; fixed_width=true; : image_button { height=2; aspect_ratio=1; key = "color_preview"; } } :text { label = "ÇäÊÎÇÈ";} :text { label = "Ñä";} } } : boxed_radio_row{ fixed_width = false; children_alignment = centered; label = "äæÚ ÓÇÎÊãÇä:"; key = "building_type"; : radio_button { label = "ãÓ˜æäí"; key = "residential";} : radio_button { label = "ÊÌÇÑí"; key = "commercial"; } : radio_button { label = "ÂãæÒÔí"; key = "educational"; } : radio_button { label = "Úãæãí"; key = "public";} : radio_button { label = "ãÐåÈí"; key = "religious";} : radio_button { label = "ÕäÚÊí"; key = "industrial";} } spacer ; :row { alignment = centered; fixed_width = false; : column { : edit_box { key = "tedade_tabaghat"; edit_width = 10; alignment = centered; fixed_width = true; } : text { label = "ÊÚÏÇÏ ØÈÞÇÊ"; alignment = centered; } } : column { : edit_box { key = "tedade_vahed"; edit_width = 10; alignment = centered; fixed_width = true; } : text { label = "ÊÚÏÇÏ æÇÍÏ"; alignment = centered; } } : column { : edit_box { key = "tabaghe_vahed"; edit_width = 10; alignment = centered; fixed_width = true; } : text { label = "ØÈÞå æÇÍÏ"; alignment = centered; } } : column { : edit_box { key = "jahate_vahed"; edit_width = 10; alignment = centered; fixed_width = true; } : text { label = "ÌåÊ æÇÍÏ"; alignment = centered; } } } : spacer { width = 0.6; fixed_width = true; } :row{ width = 80; fixed_width = true; alignment = centered; : image { //define image tile key = "im11" ; //give it a name height = 0.06; //and a height width = 1.0 ; //and now a width color = green; //set the colour } : image { //define image tile key = "im22" ; //give it a name height = 0.1; //and a height width = 1.0 ; //and now a width color = white; //set the colour } : image { //define image tile key = "im33" ; //give it a name height = 0.1; //and a height width = 1.0 ; //and now a width color = red; //set the colour } } : spacer { width = 0.6; fixed_width = true; } :row{ alignment = right ; fixed_width=true; : boxed_column { label = "ÇØáÇÚÇÊ ãÇá˜"; children_fixed_height = true ; children_fixed_width = true; alignment = top ; : row { : edit_box { key = "name"; width = 25; } : spacer {} : text { label = "äÇã æ äÇã ÎÇäæÇÏí"; alignment = centered; } } : row { : edit_box { key = "father_name"; width = 25; } : spacer {} : text { label = "äÇã ÏÑ"; alignment = centered; } } : row { : edit_box { key = "personal_code"; width = 25; edit_limit = 10; } : spacer {} : text { label = "˜Ï ãáí"; alignment = centered; } } : row { : edit_box { key = "address"; width = 25; } : spacer {} : text { label = "ÂÏÑÓ"; alignment = centered; } } : boxed_column { alignment = centered; height = 2; fixed_width = false; : row { fixed_width = true; fixed_height = true; alignment = centered; : text { label = "ÇäÏÇÒå ãÊä"; alignment = centered; vertical_margin = none; } : edit_box { key = "txt_size"; edit_width = 5; fixed_width = true; alignment = centered; vertical_margin = none; } : image_button { key = "txt-pik"; width = 3.5; aspect_ratio= 1.0 ; } } } } : boxed_column { children_fixed_width = true; fixed_width=true; label = "ÇØáÇÚÇÊ ãÌÑí"; : row { : edit_box { key = "company_name"; width =25; } : spacer {} : text { label = "äÇã ÔјÊ"; alignment = centered; } } : row { : edit_box { key = "boss_name"; width = 25; } : spacer {} : text { label = "äÇã ãÏíÑ ÚÇãá"; alignment = centered;} } : row { : edit_box { key = "melli_code"; width = 25; edit_limit = 10; } : spacer {} : text { label = "˜Ï ãáí"; alignment = centered; } } : row { : edit_box { key = "shomare_parvaneh"; width = 25; } : spacer {} : text { label = "ÔãÇÑå ÑæÇäå"; alignment = centered; } } : row { : edit_box { key = "shomare_sabt"; width = 25; } : spacer {} : text { label = "ÔãÇÑå ËÈÊ"; alignment = centered; } } : row { : edit_box { key = "address_mojri"; width = 25; } : spacer {} : text { label = "ÂÏÑÓ"; alignment = centered; } } } } spacer; // Copyright : row { alignment = right; : text { label = "© Mr. Eslami 2025"; key = "aut"; alignment = right; } } : row { alignment = centered; : button { key = "accept"; label = "ÊÃííÏ"; is_default = true; } : button { key = "cancel"; label = "ÇäÕÑÇÝ"; is_cancel = true; } } } yes. Quote
mohammadreza Posted June 9, 2025 Posted June 9, 2025 On 6/2/2025 at 8:36 PM, Lee Mac said: Does your DCL file define the appropriate image_button tile with key "txt-pik". hi bro could you help me please ? Quote
Lee Mac Posted June 9, 2025 Author Posted June 9, 2025 29 minutes ago, mohammadreza said: hi bro could you help me please ? Your x & y vector lists are constructed incorrectly. 1 Quote
Lee Mac Posted June 30, 2025 Author Posted June 30, 2025 Incremental Numbering Suite Version 4.0 Released. The main feature of the new version is the introduction of a dedicated 'Content Builder' to facilitate the construction of an incrementing string from an arbitrary number of incrementing and/or static components. With this feature, the user now has the ability to independently control the increment amount and increment frequency for each component of the string, enabling multiple sections of the string to increment by different amounts and at different rates to one another. The new version also introduces the ability to load & save application configurations, streamlining the operation of the program for multiple numbering systems. 4 2 Quote
Lee Mac Posted June 8 Author Posted June 8 I've now updated this program to support resetting components of the incrementing string back to a given value with a given frequency - the latest version can be downloaded from my site: https://lee-mac.com/numinc.html 4 3 Quote
