jiunming Posted April 13, 2009 Posted April 13, 2009 Hi..i am doing assignment for my autocad 2002..but i have difficulty with this "M10*1.5 TO diameter 20 HOLE" which used to describe 2 cyclinders in an object. Anyone can explain to me what does it means..Thanks for help Quote
kencaz Posted April 13, 2009 Posted April 13, 2009 first number would be the size and the second is the pitch. 1.5 being a course pitch... KC Quote
Organic Posted April 13, 2009 Posted April 13, 2009 Pitch is the angle it is leaning at. i.e. if a roof has a pitch of 20 degrees, it slopes up to the ridgeline at an angle of 20 degrees etc. Quote
JD Mather Posted April 13, 2009 Posted April 13, 2009 Pitch is the angle it is leaning at. i.e. if a roof has a pitch of 20 degrees, it slopes up to the ridgeline at an angle of 20 degrees etc. Uhmm, not exactly in this case. Pitch is the distance from a point on the thread to the next same point on the thread. For a single thread it is also the lead, the distance the fastener would translate (advance) in one rotation. This should be covered in a diagram in your textbook. http://home.pct.edu/~jmather/content/CAD238/AutoCAD%202007%20Tutorial%204.pdf see Figure 5 the 1.5mm distance from one turn of the helix to the next turn. Quote
