ruly_ok Posted April 14, 2009 Posted April 14, 2009 I'm using Autocad 2007. But there is no option to export the drawing to *.3ds The command 3dsout doesn't work either. Is Autocad 2007 doesn't have this features? Quote
ReMark Posted April 14, 2009 Posted April 14, 2009 The feature was left out of AutoCAD 2007 and 2008. To fix the problem take a look at this from AutoDesk: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9481286&linkID=9240618 Make sure you download and install the correct version for your system. Quote
ruly_ok Posted April 15, 2009 Author Posted April 15, 2009 Thank's for your help. I,m not really good speaking in english. Quote
ReMark Posted April 15, 2009 Posted April 15, 2009 You're welcomed ruly_ok. I'm not good at hearing in english. We make quite the team. Did you get your problem solved? Quote
