Extrude problems
When I try to extrude this it always extrude in the Y direction. How can I extrude it in the Z direction? thanks.
I am unable to duplicate your problem.
How are you arriving at this situation?
Is that a Spline shape that you've converted to an editable poly?
How are you Extruding? Are you using the Extrude modifier, or are you doing a manual Extrude or are you using the Extrude dialog?
If you're using the Extrude dialog, have you tried all three options?
All poly lines are on the x,z axis there for y is the only way it will extrude I would say.
  • 2 weeks later...
I found it in another forum. create a new object then attach, extrude. It will take the z direction of the new object then delete the element of the new object.
  • 1 year later...
Hi friends
How can I extrude it in the Z direction in 3ds max after importing from Autocad?
I have a problem (it always extrude in the Y direction)
I need your help. are there any forums that can help me in this?
thank you
hi
i want to ask you why does it always extrude in the Y direction??? This is necessary to me because if I know why , I can avoid this problem in future.
thank you
