is it possible to crop on auto cad 2004 LT rather than using trim.......which takes ages!!!
Please help Thanks
Alex
What is it that you are trying to trim or crop that takes so long?
i have a os map but need only a small section...
Too bad it's LT as I'd suggest the Extrim command (AutoLisp).
Well, you can always use copy-paste and wblock. Both have an option to reproduce part of a file.
For cleaning up unwanted parts you will still use trim alot. Be reminded though that trim has fence option.
thanks for your help copy and paste seems to work once i explode the drawing thanks
Alex
