How does one capture the imageframe setting and set something to it?
(setq Iframe...
I'm after turning the image frame on and then returning it to it's original number, but i'm not sure how to capture the original number.
There are no variables for this command
so you may have to do it like this:
(setq IFRAME-ON (command "_.IMAGEFRAME" "ON"))
(setq IFRAME-OFF (command "_.IMAGEFRAME" "OFF"))
The Buzzard
When using imageframe the options are 0, 1, 2 so the whole on/off part won't work. On every drawing that I have dealt with the imageframe has always been set to zero, but I just wanted to try and capture that integer and set it back.
Once again but this time from AutoCAD help section
Commands IMAGEFRAME
Controls whether image frames are displayed or hidden from view
System Variables No entries.
There are no variables unless you set to a variable yourself.
I do not believe that is part of the same command Lee.
IMAGEHLT set to zero makes it so the border hightlits if on when over the image border. If set to one it makes a cross pattern over the image when selected or if hovering over border that is set at 45deg box pattern.
My mistake - sorry guys :oops:
Try this
(defun C:IMGFRAME ()
 (setq IFRAME (getint "\nEnter An Integer:"))
   (if
     (= IFRAME 1)
   (if
     (= IFRAME 0)
(setq iframe (cdr (assoc 70 (dictsearch (namedobjdict) "ACAD_IMAGE_VARS"))))
0 => Imageframe set to Off
1 => Imageframe set to On
3 => Imageframe set to On but will not plot
Just ran it.
That is something wizman!
Try this
   (if
     (= IFRAME 1)
   (if
     (= IFRAME 0)
Buzzard, I'd be more inclined to use COND in this instance:
(defun C:IMGFRAME  (/ IFRAME)
 (initget 5)
 (cond ((= IFRAME 1)
       ((= IFRAME 0)
       (T (princ "\nNo a Valid Integer")))
 (princ))
Not meaning to sounds critical - only helpful :thumbsup:
Your known to be more precise Lee.
We have come to expect that.
And I would not expect less.
I just did that one fast off the top of my head.
But thats excellent.
What do you expect from a Buzzard with a bird brain.
