Hello all,
I got a LISP that allows users to select a polyline, and that boundary is used to manipulate some entities.
Now, i got a question if it is possible to have an option to allow a user to draw a polyline during the LISP execution.
So, to make the INITGET function and such aint the problem, but.....
Is it possible to call the POLYLINE command, and 'pause' until the user closes that polyline, and then do something with that polyline?
So.. the PLINE command is executed, and when finished, use (setq ensel (entlast)), so i can do anything with the ensel symbol?
I manage to 'pause' the command to ask for use imput, but allow multiple points to be selected and 'close'... is next level.
Of course...
(prompt "\nCommand PLINE is activated and you can pick points - to finish - type \"C\" for closing it, or ENTER to leave LWPOLYLINE open...")
(command "_.pline")
(while (< 0 (getvar (quote cmdactive)))
  (command "\\")
Another variant, by using (vl-cmdf) function...
(vl-cmdf "_.pline")
  (vl-cmdf "\\")
Note that this snippet won't work with (command-s) function...
@marko_ribar
Thanks Marko, this works very well!
I never used the 'cmdactive' function before. 🙂
