raj banerjee Posted January 4, 2008 Posted January 4, 2008 Can anyone let me know of a macro which would open a template, and as soon as the drawing has opened, promt to save as? it is for a pull down menu I have created for titleblocks Any help would be great:) Quote
Guest LElkins Posted January 4, 2008 Posted January 4, 2008 Raj, Check the attached file. It is a dvb, so to edit open in vba editor in autocad. This can then be stored in a central locationed and accessed via a custom button/pull down menu in autocad. If you need any help with vba then just ask and I will be more than happy to provide a step-by-step guide to help. I haven't added any error handling to the code, but can do if what I have provided is what you want. Cheers Quote
dcowell Posted October 30, 2008 Posted October 30, 2008 I'm tring to do this too in my custom pulldown menu. However, the attachement you refer to is not avail. as far as I can tell. Can you post it again along with directions. I've not used VBA Thank you! Quote
