sergiu_ciuhnenco Posted February 10 Posted February 10 I ask DEEPSEEK : Can you make please for me app for autocad wich enables the STRETCH command to stretch dynamic blocks when the crossing windows catch the dynamic parameter grips. Supported parameters are Point parameters, Polar parameters, and Linear parameters, XY parameter It provide me this code : I compile it , try it but it does not work ! May be somebody have a solutions for STRETCHING DYNAMIC BLOCKS like in this app : Stretch app Thanks in advance !!! Quote using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.Geometry; using Autodesk.AutoCAD.Runtime; using System; using System.Collections.Generic; namespace DynamicBlockStretch { public class StretchHandler : IExtensionApplication { public void Initialize() { Application.DocumentManager.MdiActiveDocument.CommandWillStart += OnCommandWillStart; } public void Terminate() { } private void OnCommandWillStart(object sender, CommandEventArgs e) { if (e.GlobalCommandName == "STRETCH") { e.Veto(); CustomStretch(); } } private void CustomStretch() { Document doc = Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor ed = doc.Editor; try { // Select objects using crossing window PromptSelectionResult psr = ed.GetSelection(new PromptSelectionOptions(), new SelectionFilter()); if (psr.Status != PromptStatus.OK) return; // Get stretch points PromptPointResult pprBase = ed.GetPoint("\nSpecify base point: "); if (pprBase.Status != PromptStatus.OK) return; Point3d basePoint = pprBase.Value; PromptPointResult pprDisplacement = ed.GetPoint("\nSpecify second point: ", new PromptPointOptions { UseBasePoint = true, BasePoint = basePoint }); if (pprDisplacement.Status != PromptStatus.OK) return; Vector3d displacement = pprDisplacement.Value - basePoint; // Process each selected object using (Transaction tr = db.TransactionManager.StartTransaction()) { foreach (SelectedObject so in psr.Value) { Entity ent = tr.GetObject(so.ObjectId, OpenMode.ForRead) as Entity; if (ent is BlockReference br && br.IsDynamicBlock) { ProcessDynamicBlock(br, displacement, tr); } // Else, handle regular entities here if needed } tr.Commit(); } } catch (Exception ex) { ed.WriteMessage($"\nError: {ex.Message}"); } } private void ProcessDynamicBlock(BlockReference br, Vector3d displacement, Transaction tr) { BlockTableRecord btr = tr.GetObject(br.DynamicBlockTableRecord, OpenMode.ForRead) as BlockTableRecord; if (btr == null) return; foreach (DynamicBlockReferenceProperty prop in br.DynamicBlockReferencePropertyCollection) { Parameter param = btr.Parameters.Cast<Parameter>().FirstOrDefault(p => p.Name == prop.PropertyName); if (param == null) continue; br.UpgradeOpen(); AdjustParameter(prop, param, displacement); } } private void AdjustParameter(DynamicBlockReferenceProperty prop, Parameter param, Vector3d displacement) { switch (param) { case LinearParameter linearParam: AdjustLinearParameter(prop, linearParam, displacement); break; case PointParameter pointParam: AdjustPointParameter(prop, displacement); break; // Extend with cases for PolarParameter, XYParameter, etc. } } private void AdjustLinearParameter(DynamicBlockReferenceProperty prop, LinearParameter linearParam, Vector3d displacement) { Vector3d direction = (linearParam.EndPoint - linearParam.StartPoint).GetNormal(); double delta = displacement.DotProduct(direction); prop.Value = (double)prop.Value + delta; } private void AdjustPointParameter(DynamicBlockReferenceProperty prop, Vector3d displacement) { Point3d current = (Point3d)prop.Value; prop.Value = current + displacement; } } } Quote
