The AutoCAD Blog Posted February 12, 2025 Posted February 12, 2025 Contributed by Autodesk Community member Deepak Maini With AutoCAD widely used in infrastructure projects, one thing that I get asked about is an easy way to insert an image inside a complex area. This is where the Express Tools > Super Hatch command is convenient, as it allows you to use an image as a fill pattern, as shown below. You can select the image, define its placement point, and then click inside the region for the image to crop to the shape of that region. It’s as easy as that! Learn More Enjoyed this article? Then check out the Autodesk Community for even more great content from talented users across Design and Make industries. The post Quick Tip: Using an Image as a Hatch in AutoCAD appeared first on AutoCAD Blog. View the full article Quote
