always I get a message "no function definition: VLA-PUT-BACKGROUNDFILLCOLOR" , but it works, what is the mistake ?
(defun c:ApplyMaskGreen (/ ss i ent txtObj)
  ;; Prompt the user to select text objects
  (setq ss (ssget '((0 . "TEXT,MTEXT"))))
  ;; Check if any text objects were selected
  (if ss
      ;; Loop through each selected text object
      (setq i 0)
      (while (< i (sslength ss))
        (setq ent (ssname ss i))
        (setq txtObj (vlax-ename->vla-object ent))
        ;; Apply background mask properties
        (if (vlax-property-available-p txtObj 'BackgroundFill)
            (vla-put-BackgroundFill txtObj :vlax-true)
            (vla-put-BackgroundFillColor txtObj 3)  ;; Green color (ACI color index 3)
            (vla-put-BackgroundFillGapFactor txtObj 1.0)  ;; Border offset factor = 1
            (vla-put-BackgroundFillUseDrawingBackgroundColor txtObj :vlax-false)  ;; Uncheck "Use drawing background color"
          (princ "\nBackgroundFill property not supported for this object.")
        ;; Increment counter
        (setq i (1+ i))
      (princ "\nBackground mask applied to selected text.")
    (princ "\nNo text objects selected.")
Edited by SLW210
Added Code Tags!
Please use Code Tags in the future. (<> in the editor toolbar)
In these cases always write '(vl-load-com)' at the beginning, just in case.
I don't know all the methods available in Visual Lisp by heart, and even less so without a PC in front of me. But it's possible that the method isn't implemented.
Try setting the property using
(vlax-put-property txObj "BackGroundFillColor" 3)
TEXT entities don't have BackgroundFill property, but MTEXT have...
Here is my slight intervention to your code :
(defun c:ApplyMaskGreen ( / ss i ent txtObj )
  (if ss
      (setq i 0)
            (setpropertyvalue ent "BackgroundFillColor" "3")
            ;; (vla-put-BackgroundFillColor txtObj 3)  ;; Green color (ACI color index 3)
            ;; (vla-put-BackgroundFillGapFactor txtObj 1.0)  ;; Border offset factor = 1
            ;; (vla-put-BackgroundFillUseDrawingBackgroundColor txtObj :vlax-false)  ;; Uncheck "Use drawing background color"
        (setq i (1+ i))
