Jared A Posted February 18 Posted February 18 I am using the following macro: ^C^C._ZOOM;_E;._QSAVE;$M=$(if,$(eq,$(getvar,DWGTITLED),0),~);._CLOSE; We are always zooming, setting scale 1 to 1, saving and then closing. Is there anyway to inject "set the scale to 1 to 1" before saving? Is there a way to make this happen for all open sheets in the window at one time? no as important as the first question. Quote
Steven P Posted February 19 Posted February 19 Copied and pasted from my Lisp Library: The first are useful functions to have to hand. For example "ZA" - Zoom All I use all the time in preference to "Zoom" "All" "Closer" closes document, no save "VPScale" sets all viewports to 1:1 scale in that sheet Put together in MyClose at the end. Load them all up and it should be OK ;;;;SubFunctions, Useful to have anyway;;;; ;;;;Zooms: ZE - extents, ZA - All, ZO - Object, ZP - Previous (defun c:ze() ;;Zooms extents, then zooms out 0.95x (command "zoom" "e" "zoom" ".95x")(princ) ) (defun c:za() ;;Zoom all, then zooms out 0.95x (command "zoom" "a" "zoom" ".95x")(princ) ) (defun c:zo() ;;Zoom object (command "zoom" "o" "zoom" "0.95x")(princ) ) (defun c:zp() ;;Zoom previous (command "zoom" "p")(princ) ) ;;;;asave: Save Lisp (defun c:asave( / currentversion saveasversion old) (setq vars '("CMDECHO" "FILEDIA")) ;;Disable command promts and echo vars (setq old (mapcar 'getvar vars)) ;;Record current vars (mapcar 'setvar vars '(0 0)) ;; Change vars (if (= 1 (getvar "dwgtitled"))(command "qsave")) ;; EXISTING DRAWING (if (= 0 (getvar "dwgtitled")) (COMMAND "_.saveas" "" "~") ) ;;new drawing (mapcar 'setvar vars old) ;;reset command prompt and echo (princ) ) ;;;;closer: Closes drawing, no save (defun c:closer( / *doc* opendrawings) (if (= dbmod 0)(command ".close")) ;; Close if drawing is saved (if (/= dbmod 0)(command ".close" "y")) ;; Close if drawing is not saved ) ;;;; VPScale: Sets all viewports in sheet to 1:1 (defun c:VPScale ( / MySS scale acount) (setq MySS (ssget "_X" '((0 . "VIEWPORT")))) ;; Select all viewports (setq acount 0) ;; A counter (setq scale 1) ;;1 = 1:1 ;; Scale to use (while (< acount (sslength MySS)) ;; loop through selection set (vla-put-customscale (vlax-ename->vla-object (ssname MySS acount)) scale) ;; Set viewports scales (setq acount (+ acount 1)) ) ; end while ) ;;;;; End sub routines ;;;;; ;;;;Zoom extents, all viewports to 1:1, save, close (defun C:MyClose ( / LayList CurrentLay Lay) (setq LayList (layoutlist)) ;; Get layout List (ACAD 2023+) (setq CurrentLay (getvar "ctab")) ;; Record current layout (foreach Lay LayList ;; Loop through each layout (setvar "ctab" Lay) ;; Change layout (c:ZE) ;; Run ZE: Zoom Extents (above) (c:vpscale) ;; Run VPScale, set all viewports to 1:1 ) ; end foreach ;; End loop (setvar "ctab" CurrentLay) ;; Return to previous sheet (c:asave) ;; Save (c:closer) ;; Close ) 1 Quote
Jared A Posted February 19 Author Posted February 19 I see the viewport scale set to 1:1. My mistake, I should have clarified that I want to set the overall sheet scale to 1:1 and not change the viewports. Thanks for the info. I will work with what you have shown. 1 Quote
Jared A Posted February 19 Author Posted February 19 when on the layout page, we set the scale back to 1:1 with nothing selected so that the x-referenced drawings will show correctly, i.e. dashed lines, hatching, etc. this does not change the scale of the viewports which are sometimes set to 1/4 or 1/8 scale. on our shortcut commands it says "setup 1:1", not sure if that helps. Quote
mhupp Posted February 20 Posted February 20 7 hours ago, Jared A said: when on the layout page, we set the scale back to 1:1 with nothing selected so that the x-referenced drawings will show correctly, i.e. dashed lines, hatching, etc. How big is your printer? Sound like you have PSLTSCALE turned off. 1 Quote
Jared A Posted February 20 Author Posted February 20 PSLTSCALE is on, I checked. Our printer will do up to 22x34 but to save paper costs we print 11x17. Our drawings are set for a standard paper size of 22x34. Even when not printing, looking at the sheet shows lines solid when they should be dashed if the paper space isn't set to 1:1. Quote
Steven P Posted February 20 Posted February 20 I don't recognise the drop down list you have there - might be a setting I don't have turned on - or is that a custom button / macro / LISP (and if so.... are you able to post the details, might be something else going on in the background apart from scale at 1:1) Is it Annotation scale? (I think variable cannoscale does that) - you can replace: (vla-put-customscale (vlax-ename->vla-object (ssname MySS acount)) scale) ;; Set viewports scales line with whatever setting needs changing Quote
Jared A Posted February 20 Author Posted February 20 i got it figured out, this is what it is for reference: this used our variables we created years ago. Thank you for your help. ^C^C._ZOOM;_E;_fillet;radius;0.0625;chamfera;0.0625;_chamferb;0.0625;dimasz;0.0625;dimcen;0;dimdli;0;dimexe;0.0625;dimexo;0.0625;dimgap;0.0625;dimtxt;0.1;donutid;0;donutod;0.5;gridunit;1,1;hpscale;0.25;hpspace;0.25;ltscale;0.208;offsetdist;1;snapunit;1,1;textsize;0.1;dimclrt;7;limits;0,0;36,24;dimscale;1;_chamfera;0.0625;chamferb;0.0625;dimasz;0.0625;dimcen;0;dimdli;0;dimexe;0.0625;dimexo;0.0625;dimgap;0.0625;dimtxt;0.1;donutid;0;donutod;0.5;gridunit;1,1;hpscale;0.25;hpspace;0.25;ltscale;0.208;offsetdist;1;snapunit;1,1;textsize;0.1;dimclrt;7;limits;0,0;36,24;getvar;dimscale;1;_QSAVE;$M=$(if,$(eq,$(getvar,DWGTITLED),0),~);._CLOSE; 1 1 Quote
mhupp Posted February 21 Posted February 21 8 hours ago, Jared A said: Our printer will do up to 22x34 but to save paper costs we print 11x17. I was trying to make a very bad dad joke 1 Quote
