maahee Posted February 22, 2025 Posted February 22, 2025 (if (= (cdr (assoc 0 bm)) "LWPOLYLINE") ; Check if the entity type is LWPOLYLINE (progn (setq pline (cdr (assoc -1 bm))) (setq pdb (entget pline)) ; Get the entity list for the selected polyline. (foreach sublist pdb (if (= (car sublist) 10) ; Look for vertex points (coded as 10). (progn (setq p1 (cdr sublist)) ; Get the point coordinates. (setq p2 (cadr sublist)) (command "_.chprop" pline "" "_lw" "10.00" "") (command "DIMALIGNED" p1 p2 "@0.35<180") ; Create aligned dimension. ) ; end progn ) ; end if ) ; end foreach ) ; end progn ) ; if       (setq p2 (cadr sublist))     I can't find the second coordinate of the polyline Quote
Lee Mac Posted February 22, 2025 Posted February 22, 2025 The second point will be encountered in another iteration of the foreach loop; you should construct a list of the points encountered within the foreach loop and then access the first & second elements of the list using car & cadr, outside of the foreach loop. 1 Quote
maahee Posted February 22, 2025 Author Posted February 22, 2025 (edited) (command "DIMALIGNED" "" "" "@1,1") Â Edited February 22, 2025 by maahee Quote
maahee Posted February 22, 2025 Author Posted February 22, 2025 22 minutes ago, Lee Mac said: The second point will be encountered in another iteration of the foreach loop; you should construct a list of the points encountered within the foreach loop and then access the first & second elements of the list using car & cadr, outside of the foreach loop. can I use (DIMALIGNED double enter then select polyline segment)Â (command "DIMALIGNED" "" "" "@1,1") Â Quote
GLAVCVS Posted February 22, 2025 Posted February 22, 2025 Just make the iteration skip ahead while pt1 and pt2 are not assigned  (if (= (cdr (assoc 0 bm)) "LWPOLYLINE") ; Check if the entity type is LWPOLYLINE (progn (setq pline (cdr (assoc -1 bm))) (setq pdb (entget pline)) ; Get the entity list for the selected polyline. (foreach sublist pdb (if (= (car sublist) 10) ; Look for vertex points (coded as 10). (progn (if pt2 (setq pt1 pt2 pt2 (cdr sublist)) (if pt1 (setq pt2 (cdr sublist)) (setq pt1 (cdr sublist)) ) ) ;;; (setq p1 (cdr sublist)) ; Get the point coordinates. ;;; (setq p2 (cadr sublist)) ;;;(command "_.chprop" pline "" "_lw" "10.00" "") (if (and pt1 pt2) (command "DIMALIGNED" pt1 pt2 "@0.35<180") ; Create aligned dimension. ) ) ; end progn ) ; end if ) ; end foreach ) ; end progn )  1 Quote
GLAVCVS Posted February 22, 2025 Posted February 22, 2025 (edited) I disabled the line '(command "_.chprop" pline "" "_lw" "10.00" "")' it only needs to be executed once. Place it before 'foreach' Edited February 22, 2025 by GLAVCVS 1 Quote
GLAVCVS Posted February 22, 2025 Posted February 22, 2025 This code means that pt1 and pt2 should be 'nil' at the beginning of each polyline process 1 Quote
Lee Mac Posted February 22, 2025 Posted February 22, 2025 2 hours ago, maahee said: can I use (DIMALIGNED double enter then select polyline segment)Â (command "DIMALIGNED" "" "" "@1,1") Â Â You seem to have ignored my suggestion. 1 Quote
maahee Posted February 22, 2025 Author Posted February 22, 2025 2 hours ago, Lee Mac said:  You seem to have ignored my suggestion. I can't understand how to do it. use of nested foreach. I am beginner of autolisp language Quote
Steven P Posted February 22, 2025 Posted February 22, 2025 Steps as Lee Mac Suggests - Use ForEach to create a list of points (assoc 10) - End ForEach - Loop through list of points (n-1) times where n is the list length - Put in your dimension - End Loop  Often there is a function out there that can 'plug and play' into a routine... below is a subfunction massoc which I find really handy, often using the 2nd option in the 2nd post... 'Key' in your case will be 10 lst in your case will be pdb (though you might be able to also use (entget bm)  The return is a list of all the keys, in your case the points, I think in the format (10 pt-X pt-Y pt-Z), so (CADR... to get the points only.    1 Quote
BIGAL Posted February 22, 2025 Posted February 22, 2025 This is what I use and I am pretty sure it was posted by Lee-mac many years ago. Â (setq plent (entsel "\nPick pline ")) (if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent)))))) so if you want pt1 pt2 (setq pt1 (car co-ord) pt2 (cadr co-ord)) You can also use the Vl functions getstartpoint & getendpoint 1 Quote
Tharwat Posted February 22, 2025 Posted February 22, 2025 (edited) Based on your way of processing, here is what I think is what you are after. (if (and (setq s (car (entsel "\nSelect LWpolyline : "))) (= (cdr (assoc 0 (setq bm (entget s)))) "LWPOLYLINE") ) (progn (foreach grp bm (if (= (car grp) 10) (setq pts (cons (cdr grp) pts)) ) ) (entmod (append bm '((370 . 10)))) (setq p1 (car pts)) (foreach pt (cdr pts) (command "DIMALIGNED" "_non" p1 "_non" pt "@0.35<180") (setq p1 pt) ) ) ) Â Edited February 23, 2025 by Tharwat 1 Quote
GLAVCVS Posted February 23, 2025 Posted February 23, 2025 (edited) I see there is consensus on the idea of getting each pair of points by executing 'foreach' twice In my case, I'm going to insist on getting it in just 1, reducing the executed code as much as possible (or at least that's what I think) and preserving the original code as much as possible. I suppose there will be differences of opinion on this  (defun c:myDimAlign (/ bm pline sublist pt1 pt2) (if (and (setq pline (car (entsel "\nSelect any LWpolyline..."))) (= (cdr (assoc 0 (setq bm (entget pline)))) "LWPOLYLINE"); Check if the entity type is LWPOLYLINE ) (progn (command "_.chprop" pline "" "_lw" "10.00" "") (foreach sublist bm (if (= (car sublist) 10) ; Look for vertex points (coded as 10). (if pt2 (command "DIMALIGNED" (setq pt1 pt2) (setq pt2 (cdr sublist)) "@5<180") (if pt1 (command "DIMALIGNED" pt1 (setq pt2 (cdr sublist)) "@5<180") (setq pt1 (cdr sublist)) ) ) ; end progn ) ; end if ) ; end foreach ) ; end progn ) )  Edited February 23, 2025 by GLAVCVS 1 Quote
GLAVCVS Posted February 23, 2025 Posted February 23, 2025 11 hours ago, Tharwat said: Based on your way of processing, here is what I think is what you are after. (if (and (setq s (car (entsel "\nSelect LWpolyline : "))) (= (cdr (assoc 0 (setq bm (entget s)))) "LWPOLYLINE") ) (progn (foreach grp bm (if (= (car grp) 10) (setq pts (cons grp pts)) ) ) (entmod (append bm '((370 . 10)))) (setq p1 (car pts)) (foreach pt (cdr pts) (command "DIMALIGNED" "_non" p1 "_non" pt "@0.35<180") (setq p1 pt) ) ) ) Â Â By the way, Tharwat: I can't get your code to work Could it be my problem? Â 1 Quote
Tharwat Posted February 23, 2025 Posted February 23, 2025 3 hours ago, GLAVCVS said: Â By the way, Tharwat: I can't get your code to work Could it be my problem? Â Nothing special in the codes, but if you are not using the English version then you may need to add the prefixed symbols _. to command name. 1 Quote
GLAVCVS Posted February 23, 2025 Posted February 23, 2025 1 hour ago, Tharwat said: Nothing special in the codes, but if you are not using the English version then you may need to add the prefixed symbols _. to command name. Â No. I've already tried those options. However, when I checked your message and looked at the code again, I thought I saw that you forgot to remove the 10 code in the first 'foreach'. Maybe that's what it is and when drawing the 'dimensions' it does so at the coordinate x=10. For this reason I didn't see the command display anything on the screen. I'll check it when I get home 1 Quote
Tharwat Posted February 23, 2025 Posted February 23, 2025 Yeah you are right, I should have retrieved the coordinates excluding the GC 10. Codes updated. 1 Quote
Tharwat Posted February 23, 2025 Posted February 23, 2025 Even though the codes should work but would draw them vertically. 1 1 Quote
Lee Mac Posted February 23, 2025 Posted February 23, 2025 6 hours ago, GLAVCVS said: I see there is consensus on the idea of getting each pair of points by executing 'foreach' twice In my case, I'm going to insist on getting it in just 1, reducing the executed code as much as possible (or at least that's what I think) and preserving the original code as much as possible. I suppose there will be differences of opinion on this  (defun c:myDimAlign (/ bm pline sublist pt1 pt2) (if (and (setq pline (car (entsel "\nSelect any LWpolyline..."))) (= (cdr (assoc 0 (setq bm (entget pline)))) "LWPOLYLINE"); Check if the entity type is LWPOLYLINE ) (progn (command "_.chprop" pline "" "_lw" "10.00" "") (foreach sublist bm (if (= (car sublist) 10) ; Look for vertex points (coded as 10). (if pt2 (command "DIMALIGNED" (setq pt1 pt2) (setq pt2 (cdr sublist)) "@5<180") (if pt1 (command "DIMALIGNED" pt1 (setq pt2 (cdr sublist)) "@5<180") (setq pt1 (cdr sublist)) ) ) ; end progn ) ; end if ) ; end foreach ) ; end progn ) )   Only one DIMALIGNED call is required, e.g.: (defun c:mydimalign ( / e p x ) (if (and (setq e (car (entsel))) (= "LWPOLYLINE" (cdr (assoc 0 (setq x (entget e))))) ) (foreach g x (cond ( (/= 10 (car g))) ( p (command "_.dimaligned" p (setq p (cdr g)) "@5<180")) ( (setq p (cdr g))) ) ) ) (princ) )  2 1 Quote
GLAVCVS Posted February 23, 2025 Posted February 23, 2025 (edited) @Lee Mac I can only do one thing with you: take my hat off. Edited February 23, 2025 by GLAVCVS Quote
