leonucadomi Posted February 24, 2025 Posted February 24, 2025 hello: Does anyone have a routine in which I can select all the texts or mtext in the window and change them to "mylayer" and color bylayer thanks Quote
GLAVCVS Posted February 24, 2025 Posted February 24, 2025 Only those visible in the graphics window or the entire drawing? Quote
leonucadomi Posted February 24, 2025 Author Posted February 24, 2025 9 minutes ago, GLAVCVS said: Only those visible in the graphics window or the entire drawing? ONLY THOSE THAT I SELECT WITH WINDOW Quote
GLAVCVS Posted February 24, 2025 Posted February 24, 2025 Maybe this will help you (defun c:trocapa (/ conj ent n) (setq n -1) (princ "\nSelect TEXTs/MTEXTs...") (if (setq conj (ssget '((0 . "*TEXT")))) (while (setq ent (ssname conj (setq n (1+ n)))) (entmod (append (entget ent) (list (cons 8 "MyLayer") (cons 62 256)))) ) ) (princ) ) 1 1 Quote
GLAVCVS Posted February 24, 2025 Posted February 24, 2025 If you want to change the name of the destination layer you just have to change the 'MyLayer' code to the name you want. 1 Quote
leonucadomi Posted February 24, 2025 Author Posted February 24, 2025 2 hours ago, GLAVCVS said: If you want to change the name of the destination layer you just have to change the 'MyLayer' code to the name you want. thanks Quote
