hello:
Does anyone have a routine in which I can select all the texts or mtext in the window and change them to "mylayer" and color bylayer
thanks
Only those visible in the graphics window or the entire drawing?
ONLY THOSE THAT I SELECT WITH WINDOW
Maybe this will help you
(defun c:trocapa (/ conj ent n)
  (setq n -1)
  (princ "\nSelect TEXTs/MTEXTs...")
  (if (setq conj (ssget '((0 . "*TEXT"))))
    (while (setq ent (ssname conj (setq n (1+ n))))
      (entmod (append (entget ent) (list (cons 8 "MyLayer") (cons 62 256))))
  • Thanks 1
If you want to change the name of the destination layer you just have to change the 'MyLayer' code to the name you want.
thanks
