extrawurscht Posted March 6, 2025 Posted March 6, 2025 Hi there, I'm looking for a simple Lisp to copy text ("TEXT" "MTEXT" "ATTRIB") and paste it to another attribute. I know that there are some, which works perfect for me: I'm using the Lisp TTC.lsp from ASMI! Awsome with the Multiple and Pair-wise Mode The only thing I have is, that if I miss the attribute or text, the lisp ends. For pick text and paste text. I tried to modify with e.g. a while T which only works for me for the Multiple Mode, and only for paste. ;-------------------------------------------------------------------------- (while T ;-------------------------------------------------------------------------- (while(setq conFlag(TTC_Paste paseStr))T ); end while ;-------------------------------------------------------------------------- );End while T ;-------------------------------------------------------------------------- There is also a possibility with errNo 7 like used in Mac Lee's CTX (= 7 (getvar 'errno)) (princ "\nMissed, try again.") Is there anyone who can help out with this and can modify this? Many Thanks and BR TTC.lsp Quote
extrawurscht Posted March 6, 2025 Author Posted March 6, 2025 for pick text I found something like this, but have absolutley no glue to implement: (defun _entsel (msg / p r) (setvar "ErrNo" 0) (while (not (cond ((and (null (setq p (entsel (strcat "\n" msg)))) (/= 52 (getvar 'errno))) (prompt "\nPick missed, try again...") ) ((null p) t) ((setq r p)) ) ) ) r ) ;; (_entsel "Pick something: ") (if (setq vbobj (car (_entsel "\nPick Something: "))) (setq vbobj (vlax-ename->vla-object vbobj)) ) Quote
pkenewell Posted March 6, 2025 Posted March 6, 2025 (edited) The trick is to replace the NENTSEL function with this: ;|============================================================================== Function Name: (pjk-Nentsel) Arguments: pr = string; a select prompt for the command line. Usage: (pjk-Nentsel <Prompt>) Returns: Returns a list containing the Entity name and the point selected in the same manner as (nentsel). Returns nil if no object is selected and Enter / Escape is initiated. Description: This routine is a wrapper for the (nentsel) function to capture a missed pick with the cursor and continue prompting for a point until a return is initiated. Improves the inherent problem using (initget) with (nentsel), forcing a pick or an escape. ================================================================================|; (defun pjk-Nentsel (pr / ent) (setvar "errno" 0) (while (and (not (setq ent (nentsel pr)))(= (getvar "errno") 7)) (princ "\nNo Object Selected. Try Again...\n") ) ent ) ;; End Function (pjk-Nentsel) See the updated attached file. Haven't had time to test it, but should do what you want. TTC.lsp Edited March 6, 2025 by pkenewell Quote
extrawurscht Posted March 6, 2025 Author Posted March 6, 2025 wow, thanks pkenewell, that was fast will try it now... Quote
extrawurscht Posted March 6, 2025 Author Posted March 6, 2025 It's working quite well! I only had to exchange of course as well for the copy text part in the code. I also added the "while T" for the Multiple like mentioned in the first post. Thanks a lot for your help! 1 Quote
pkenewell Posted March 6, 2025 Posted March 6, 2025 31 minutes ago, extrawurscht said: It's working quite well! I only had to exchange of course as well for the copy text part in the code. I also added the "while T" for the Multiple like mentioned in the first post. Thanks a lot for your help! @extrawurscht I don't think you need that "While T" loop! That makes you have to force the function to error out, try just adding: (while (setq conFlag (TTC_Paste paseStr))) It should stop the loop when there is no value for "conflag"; (TTC_paste) will return nil if you just press ENTER. Quote
extrawurscht Posted March 6, 2025 Author Posted March 6, 2025 yes, you are right, already deleted this again thanks again 1 Quote
pkenewell Posted March 6, 2025 Posted March 6, 2025 1 hour ago, extrawurscht said: yes, you are right, already deleted this again thanks again @extrawurscht FYI - There is also another "nentsel" in the (TTC_copy) sub-function. I recommend you change to "pjk-nentsel" in that location as well. (defun TTC_Copy (/ sObj sText tType actDoc) (if (and (setq sObj (car (pjk-Nentsel "\nCopy text... "))) ;<-- Here ... Quote
