jylai Posted March 13, 2025 Posted March 13, 2025 The attachment is just a simple example T3.dwg Quote
BIGAL Posted March 14, 2025 Posted March 14, 2025 (edited) 1st your example dwg is flat the pipe is not 3D. Ok rather than code this is how I would do it. Fillet the pline with correct radius as required. Draw a circle that is dia on end point of pline Ucs ob pick pline near circle Use Rotate3d to rotate the circle to a vertical alignment look at Ucs Icon I used Y axis 90. Use extrude path UCS W All done` You need to practice your 3d solid skills. I made this faster than I could write code. Edited March 14, 2025 by BIGAL Quote
