_GerG_ Posted April 20, 2009 Posted April 20, 2009 Evening guys, How do I import one .dwg into another .dwg? I've been copying and pasting them but I think there is an easier way. Thanks. Quote
Dipali Posted April 20, 2009 Posted April 20, 2009 you can use 'insert' if you want that dwg to be part of your new dwg. or if you need that dwg only for reference than you can use 'xref' Quote
_GerG_ Posted April 20, 2009 Author Posted April 20, 2009 you can use 'insert' if you want that dwg to be part of your new dwg.or if you need that dwg only for reference than you can use 'xref' alright cool thanks for the help. Quote
Organic Posted April 20, 2009 Posted April 20, 2009 Copy and paste (to original coordinates if possible) is just as easy. Quote
