Hello all,
i am looking for a way to detect undershoots and overshoots between all polylines in a drawing.
Now i found the intersection functions of @Lee Mac.
I made the code below, and works fine... but...
When polylines are FAR apart from eachother, there also detected and marked...
Is there a simple fix, so the 'intersection' is limited to max 0.50 m, so only small gaps are detected?
			(setq ss (ssget "_X" (list (cons 410 "Model") (cons 0 "LINE,LWPOLYLINE,ARC"))))
			(if ss
					(setq i 0)
					(repeat (sslength ss)
						(setq ensel1 (ssname ss i))
						(setq ii 0)
							(setq ensel2 (ssname ss ii))
							(foreach pnt (LM:intersections (vlax-ename->vla-object ensel1) (vlax-ename->vla-object ensel2) acextendotherentity)
								(entmakex (list (cons 0 "CIRCLE")
									(cons 10 pnt)
									(cons 40 1)  ; Circle size
									(cons 62 3))
							(setq ii (+ 1 ii))
						(setq i (+ 1 i))
(defun LM:intersections ( ob1 ob2 mod / lst rtn )
    (if (and (vlax-method-applicable-p ob1 'intersectwith)
             (vlax-method-applicable-p ob2 'intersectwith)
             (setq lst (vlax-invoke ob1 'intersectwith ob2 mod))
        (repeat (/ (length lst) 3)
            (setq rtn (cons (list (car lst) (cadr lst) (caddr lst)) rtn)
                  lst (cdddr lst)
    (reverse rtn)
You would need to iterate over the resulting intersections and exclude/ignore those which exceed your desired distance from the source entity.
Hi all,
Found the mising link:
(setq newPt (vlax-curve-getClosestPointTo obj pnt))
this allowed me to do the check between the point and the original entity. Thanks for the direction @Lee Mac
