mgalicki Posted April 20, 2009 Posted April 20, 2009 I have a problem with Dialog box generation.This is even in a fresh new BLANK drawing. 2 layers, no entities. Several Dialog boxes do it: xref & hatch, but NOT the printer or Layers db's. It has nothing to do with the drawing, it's the hardware or O/S. I have tweaked the display settings to no end, well hopefully there's one I missed that will cure the disfunction. I've copied the settings from other machines that are identical but notta?? Thanks for you efforts, mgalicki Quote
MaxwellEdison Posted April 21, 2009 Posted April 21, 2009 is the mysterious FILEDIA system variable set to 1? Quote
mgalicki Posted April 21, 2009 Author Posted April 21, 2009 It sure is, but it also acts the same way when set to 0. Thanks Quote
Tiger Posted April 21, 2009 Posted April 21, 2009 Since you say it's a hardware thing - you mind giving us your specification on the hardware? A blank drawing you say, one with your own template? or one with no template? Quote
mgalicki Posted April 21, 2009 Author Posted April 21, 2009 this happens with any template, mine and even the acad one out of the box from another machine. Thanks for the reply. mgalicki Quote
mgalicki Posted April 22, 2009 Author Posted April 22, 2009 Dell Vostro_200 Intel core 2 duo E8200@266GHz 2 GB of RAM Invidia GeForce 8300 GS Driver 6.14.11.5828 Dell 2009WT flat panel Hitachi IDE HDP725025GLA380 MW XP Professional Ver 2002 SP 3 Quote
