dilan Posted April 5 Posted April 5 Hi, I’m trying to automate exporting a surface to an .xml file by creating a LISP function for it. But so far, no success... Can you tell me if this is even possible? (defun ExportSurfaceToLandXML ( surfaceName saveFolder / C3D verstring prodstring datastr acadApp C3D civilDoc surfs landXMLTools surface filePath ) ;------------------ (vl-load-com) ;------------------ ; Example (ExportSurfaceToLandXML "TIN_example" "C:\\Users\\surfl\\Desktop\\New_folder") ;------------------ (setq C3D (strcat "HKEY_LOCAL_MACHINE\\" (if vlax-user-product-key (vlax-user-product-key) (vlax-product-key) ) ) C3D (vl-registry-read C3D "Release") verstring (substr C3D 1 (vl-string-search "." C3D (+ (vl-string-search "." C3D) 1) ) ) prodstring (strcat "AeccXUiLand.AeccApplication." verstring) ) (setq datastr (strcat "AeccXLand.AeccTinCreationData." verstring)) ;-------------------- (if (and (setq acadApp (vlax-get-acad-object)) (setq C3D (vla-getinterfaceobject acadApp prodstring)) (setq civilDoc (vla-get-activedocument C3D)) (setq surfs (vlax-get civilDoc 'surfaces))) (progn (if (not (vlax-property-available-p civilDoc "LandXMLTools")) (progn (alert "This is not a Civil 3D document or LandXMLTools are not available!") (exit) ) ) ; Get LandXML tools (setq landXMLTools (vla-get-LandXMLTools civilDoc)) ; Trying to find a surface by name (setq surface (vl-catch-all-apply '(lambda () (vla-Item (vla-get-Surfaces landXMLTools) surfaceName) ) )) ; Checking if the surface is found (if (vl-catch-all-error-p surface) (progn (alert (strcat "Surface with name '" surfaceName "' not found!")) (exit) ) ) ; Create a full path to the file (setq filePath (strcat saveFolder "\\" surfaceName ".xml")) ; Exporting the surface to LandXML (vl-catch-all-apply '(lambda () (vla-ExportSurface surface filePath) ) ) ; Checking the success of export (if (vl-catch-all-error-p (vl-catch-all-apply '(lambda () (findfile filePath)))) (alert (strcat "Error exporting surface to file: " filePath)) (alert (strcat "The surface has been successfully exported to file: " filePath)) ) ; Returning the path to the file filePath ); end of progn ); end of if ); end of defun Most likely, I'm using the wrong Visual LISP functions. Quote
BIGAL Posted April 5 Posted April 5 This is similar but allows you to pick a surface and return its name, the vercheck does same as your get registry just a different variable name. (ah:vercheck) ; version check see vercheck.lsp (if (not AT:ListSelect)(load "Listseelct")) (vlax-for j (vlax-get *AeccDoc* 'SurfaceS) (setq lst (cons (cons (vla-get-name j) j) lst)) ) ;if length of surfaces more than 1 else skip pick if 0 then msg and exit (setq lenlst (length lst)) (if (= lenlst 0) (progn (Getstring "\nYou have no surfaces press any key to exit") (exit) ) ) (if (= lenlst 1) (setq surfacepick (car (nth 0 lst))) ; pull surface out of dotted pair ) (if (> lenlst 1) (progn (setq surfacepick (car (AT:ListSelect "Set new surface " "Select surface name" 10 10 "false" (vl-sort (mapcar (function car) lst) '<) ))) ) ; end progn ) ;end if (setq lst2 lst) ; make answer returned list2 listselect.lsp Quote
