Does anyone have a LISP that will toggle dimensions with a leader into different quadrants?
When you do a dimension it will default to the position of the dim text, but you can override it and change the dim text point. So its a 2 step process. If you look at the 15 & 25 they have been moved.
What do you know about lisp ? This is sample code you would have 4 versions of this to move the dim text. So for me a dcl with choice orientation also.
; do a dim
(setq obj (vlax-ename->vla-object (entlast)))
(setq tpos (mapcar '+ (vlax-get obj 'TextPosition) (list 125.0 (- 120.0) 0.0)))
(vlax-put obj 'TextPosition tpos)
Could do as 4 defuns but stored in one lisp program. DUL, DUR, DLL, DLR
BIGAL
I'm not at all good with writing LISPs. It is all Greek to me.  Can you write one that has the 4 functions in one LISP?
Ok I have something but I can not post, the move values for the dim text depends on your dimension style, so I need a real dwg so can work out these offset values.
Part 2 the code at moment links to the mid point is that OK, not sure have to dig deeper to see if can move it closer to an end.
Please post a dwg.
Is such an algorithm possible for this task?
Select dimension:
1st click on the dimension - dimtext moves along with the leader Top Left
2 st click                           - dimtext moves along with the leader Top right
3 st click                           - dimtext moves along with the leader Bottom left
4 st click                           - dimtext moves along with the leader Bottom right.
The offset from the dimension line should be equal to the height of the text (or two text heights).
Edited by Nikon
Multi radio buttons.lspGive this a try.
; https://www.cadtutor.net/forum/topic/97280-toggle-dimension-lisp/
; dim_sample.dwg move dime to one of the 4 quadrants
; By AlanH April 2025
(defun c:dodimcorner ( / ent obj dotl dotr dobl dobr)
(defun dotl ( / )
(setq tpos (mapcar '+ (cdr (assoc 13 entg))(list 0 dimsc 0.0)))
(vlax-put obj 'TextMovement 1)
(defun dotr ( / )
(setq tpos (mapcar '+ (cdr (assoc 14 entg))(list 0.5 dimsc 0.0)))
(defun dobl ( / )
(setq tpos (mapcar '+ (cdr (assoc 13 entg))(list 0.0 (- dimsc) 0.0)))
(defun dobr ( / )
(setq tpos (mapcar '+ (cdr (assoc 14 entg))(list 0.0 (- dimsc) 0.0)))
(if (not AH:Butts)(load "Multi radio buttons.lsp")) ; loads the program if not loaded already
(setq ent (car (entsel "\nPick a dim ")))
(setq entg (entget ent))
(setq obj (vlax-ename->vla-object ent))
(setq dimsc (vlax-get obj 'scalefactor))
(if (= but nil)(setq but 1))
(ah:butts but "V" '("Choose a corner" "Top Left" "Top right" "Bottom left" "Bottom right" ))
(cond
((= but 1)(dotl))
((= but 2)(dotr))
((= but 3)(dobl))
((= but 4)(dobr))
(c:dodimcorner)
This is great code, but Top Left and
Top right does not move the leader up.
Is it possible to sort through the placement options by clicking on the dimension (without using the dialog box)?
Edited by Nikon
While the sun floats around the globe till BIgAl wakes again, look into his code, there is a section
(cond
((= but 1)(dotl))
((= but 2)(dotr))
((= but 3)(dobl))
((= but 4)(dobr))
that can be changed to a while loop, something like below for the order of things: (Sunday, CAD is off, no testing or checks from me today)
(setq counter 1)
(While ((ssget '((0 . "*DIM*"))) : +E+S ; select any dimension else do by entity name from previous dimension, (car entg )
(cond
((= counter 1)(dotl))
setq counter (+ counter 1)
(if (= counter 5)(setq counter 1)
) ; end while
Pretty sure you can have a go at that today, then show off later
I refuse the dialog box, but I have to select the same size twice, then I can change the leader position in the loop by pressing lmb/rmb...
The problem with the top location remains...
(defun c:dodimcorner-while (/ ent obj entg dimsc but counter)
  (defun dotl (/)
    (setq tpos (mapcar '+ (cdr (assoc 13 entg)) (list 0 dimsc 0.0)))
  (defun dotr (/)
    (setq tpos (mapcar '+ (cdr (assoc 14 entg)) (list 0.5 dimsc 0.0)))
  (defun dobl (/)
    (setq tpos (mapcar '+ (cdr (assoc 13 entg)) (list 0.0 (- dimsc) 0.0)))
  (defun dobr (/)
    (setq tpos (mapcar '+ (cdr (assoc 14 entg)) (list 0.0 (- dimsc) 0.0)))
  (if (not AH:Butts)
  (if (= but nil) (setq but 1))
 ; (ah:butts but "V" '("Choose a corner" "Top Left" "Top right" "Bottom left" "Bottom right"))
  (setq counter 1)
  (while (ssget '((0 . "*DIMENSION*")))
    (cond
      ((= counter 1) (dotl))
      ((= counter 2) (dotr))
      ((= counter 3) (dobl))
      ((= counter 4) (dobr))
    (setq counter (+ counter 1))
    (if (= counter 5) (setq counter 1))
Try setting (setq counter ... ) to 2 - I'm assuming here that the initial text position is top left, so when you click dimension to move it on, the first position change will be to set position to top left - the third click will move it on to TR.
  • Thanks 1
It doesn't change anything...
Probably, the program contains only these 4 positions of the text with the leader
depending on the distance from the dimension line.
Edited by Nikon
I dont know why its not working this is what I got just now copied code from here as an extra check.
There is some code out there for use arrows I will leave that for you to find.
Edited by BIGAL
  • 6 months later...
(defun c:dodimcorner-while (/ *error* ent obj entg dimsc but counter)
(defun *error* ( msg )
(setvar 'cmdecho 0) ;; 5.28.24
  (vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
  (if msg (prompt (strcat "\n" msg)))
  (setvar 'cmdecho 1)
(defun dotl (/)
  (defun dotr (/)
  (defun dobl (/)
  (defun dobr (/)
(setvar 'cmdecho 0)
  (setq counter 2)
  (while
    (cond
    (setvar 'cmdecho 1)
  (*error* nil)
;;;   UPDATE TO INCLUDE RESET ;;
(defun c:dtf (/ *error* ent obj entg dimsc but counter)
(princ "\n Move DIM Text to Another Location..") ;; https://www.cadtutor.net/forum/topic/97280-toggle-dimension-lisp/#findComment-666274
  (setvar 'cmdecho 1)
(defun dotx (/)
(princ "\n    ** Reset **..")
 (command "dim" "hometext" "_L" "")
   (command) (command) ;; resets 'dim
(defun dotl (/)
  (defun dotr (/)
  (defun dobl (/)
  (defun dobr (/)
(setvar 'cmdecho 0)
  (setq counter 2)
  (while
  (setq ent (car (entsel "\n Pick DIM: ")))
    (cond
      ((= counter 5) (dotx))
    (if (= counter 6) (setq counter 1))
    (setvar 'cmdecho 1)
  (*error* nil)
try this.. update
Edited by ScottMC
Something is missing here, in my code it was the call to the Radio button DCL
    (cond
 You only set counter to 2 ? You could do a "enter number 1-5 or press enter" Enter will add 1 to counter value. Need to wrap in a while to do this.
  (setvar 'cmdecho 1)
(defun dotl (/)
  (defun dotr (/)
  (defun dobl (/)
  (defun dobr (/)
(setvar 'cmdecho 0)
  (setq counter 2)
  (while
    (cond
    (setvar 'cmdecho 1)
  (*error* nil)
  (setvar 'cmdecho 1)
(defun dotx (/)
(defun dotl (/)
  (defun dotr (/)
  (defun dobl (/)
  (defun dobr (/)
(setvar 'cmdecho 0)
  (setq counter 2)
  (while
    (cond
    (setvar 'cmdecho 1)
  (*error* nil)
try this.. update
  (setvar 'cmdecho 1)
(defun dotl (/)
  (defun dotr (/)
  (defun dobl (/)
  (defun dobr (/)
(setvar 'cmdecho 0)
  (setq counter 2)
  (while
    (cond
    (setvar 'cmdecho 1)
  (*error* nil)
  (setvar 'cmdecho 1)
(defun dotx (/)
(defun dotl (/)
  (defun dotr (/)
  (defun dobl (/)
  (defun dobr (/)
(setvar 'cmdecho 0)
  (setq counter 2)
  (while
    (cond
    (setvar 'cmdecho 1)
  (*error* nil)
try this.. update
Scott,
This works with one problem. I hope you can fix it. The leader line becomes to long when selecting the dimension to relocate. If it could stayat the original length, this would be awesome.
Thank you for your efforts.
