mohammadreza Posted April 15 Posted April 15 hello everybody i need to change letter "ی" in Arabic language to letter"d" in English. i tried to change Entity group number (1 . "ی") but i failed .please help me. its lisp that i used. (defun c:ReplaceYInAllTexts ( / ss i ent entData txt newtxt) (princ "\nProcessing all text entities...") ;; Select all TEXT and MTEXT entities in the drawing (setq ss (ssget '((0 . "TEXT,MTEXT")))) (if ss (progn (setq i 0) (while (< i (sslength ss)) (setq ent (ssname ss i)) ; Get entity from selection set (setq entData (entget ent)) ; Get DXF data of entity (setq txt (cdr (assoc 1 entData))) ; Get the text string ;; Replace both Persian and Arabic "ی"/"ي" with "d" (setq newtxt (vl-string-translate "يی" "dd" txt)) (if (/= txt newtxt) ; If text was changed (progn (setq entData (subst (cons 1 newtxt) (assoc 1 entData) entData)) ; Replace text (entmod entData) ; Modify the entity (entupd ent) ; Update the display ) ) (setq i (1+ i)) ; Go to next entity ) (princ "\n All text entities processed and updated where needed.") ) (princ "\n No text entities found.") ) (princ) ) Quote
GLAVCVS Posted April 15 Posted April 15 Hi @Mohammedreza If '...-translate' doesn't work as expected, try '...-subst' And if that doesn't work either, convert the string to a list with 'vl-string->list' and replace the integer with the one that corresponds to the ASCII of the target character. After that, convert the resulting list again with 'vl-list->string' 1 Quote
Saxlle Posted April 15 Posted April 15 Hi @mohammadreza, Maybe you need tou use Unicode characters to replace the letter "ي" (if you look at Unicode character list Arabic, you will se the letter "ي" have "U+064A"). This is the Unicode characters for Basic Latin (letter d = U+0064). So, if I use this (if you have only one letter): (setq ent (entget (car (entsel "\nSelect TEXT or MTEXT:")))) txt (cdr (assoc 1 ent)) ) From "txt" variable I get "\U+064A" which represent the letter "ي" and, if you want to substitue the letter "ي" with letter "d", use the next line of code (entmod (subst (cons 1 "\U+0064") (cons 1 txt) ent)) where "\U+0064" represent the letter "d" I get the desired output. Also, if you have something like this "{\\fArial|b0|i0|c178|p34;\U+064A} {\\fArial|b0|i0|c178|p34;\U+064A}", use this Lee Mac UnFormat String to clean everything and get "\U+064A \U+064A". To do this, you need first to clean string to get "\U+064A \U+064A", then replace old string (for e.g. "{\\fArial|b0|i0|c178|p34;\U+064A} {\\fArial|b0|i0|c178|p34;\U+064A}") with "\U+064A \U+064A" using (entmod (subst ....), then again get data about entity, use "\U+0064 \U+0064" to substitue "\U+064A \U+064A". I know it's confusing, but you need to try it on your own. Best regards. 1 Quote
hosneyalaa Posted April 15 Posted April 15 5 hours ago, mohammadreza said: i need to change letter "ی" in Arabic language to letter"d" in English. i tried to change Entity group number (1 . "ی") but i failed .please help me. Can you attach an example drawing? Quote
Steven P Posted April 15 Posted April 15 Try this: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/find-and-replace-text/td-p/5649883 Though the usual 'find' command should do this as well Quote
