matngot Posted April 16 Posted April 16 (edited) Hello everyone! I have created a DCL dialog box for my lisp program and now I don't know how to fix my program's lisp so that the DCL dialog box works. I hope everyone can help me fix this lisp program. mc_dialog : dialog { label = "NHAP THONG SO MAT CAT DOC"; : edit_box { label = "Ty le ngang 1/?"; key = "hf"; } : edit_box { label = "Ty le dung 1/?"; key = "vf"; } : edit_box { label = "Cao do so sanh (m)"; key = "level"; } : edit_box { label = "Ly trinh diem dau (m)"; key = "st"; } : edit_box { label = "Chieu cao Text Title"; key = "th"; } : edit_box { label = "Chieu cao Text cao do"; key = "th1"; } : edit_box { label = "File du lieu TXT"; key = "file"; } : button { label = "Chon File..."; key = "chonfile"; } spacer; : row { : button { label = "Ve"; is_default = true; key = "accept"; } : button { label = "Thoat"; key = "cancel"; } } } mat doc tuyen.lsp Edited April 16 by SLW210 Added Code Tags!! Quote
SLW210 Posted April 16 Posted April 16 Please put your code in code tags! (<> in the editor toolbar) Quote
GLAVCVS Posted April 16 Posted April 16 Hi @matngot perhaps you should indicate what error AutoCAD is displaying. Primarily, it seems that the 'edit_box's' aren't sufficiently defined. Also, perhaps you should enclose them under a ': column {' Quote
Steven P Posted April 16 Posted April 16 I'd also suggest you look at action_tiles so that you can get the input to the edit box and use them, or modify the 'OK' button to do the same: Action tile might be something like this: (action_tile "hf" "(setq hf (read (get_tile \"hf\"))))" ) (a quick copy and paste example, not sure if you need the 'Read' in there) Quote
SLW210 Posted April 16 Posted April 16 Maybe work through these... Dialog Control Language (DCL) | AfraLISP Quote
BIGAL Posted April 16 Posted April 16 (edited) My $0.05, I would add a width to the edit boxes as they are all over the place. mc_dialog : dialog { label = "NHAP THONG SO MAT CAT DOC"; : column { : edit_box { label = "Ty le ngang 1/?"; key = "hf"; } : edit_box { label = "Ty le dung 1/?"; key = "vf"; } : edit_box { label = "Cao do so sanh (m)"; key = "level"; } : edit_box { label = "Ly trinh diem dau (m)"; key = "st"; } : edit_box { label = "Chieu cao Text Title"; key = "th"; } : edit_box { label = "Chieu cao Text cao do"; key = "th1"; } : edit_box { label = "File du lieu TXT"; key = "file"; } : button { label = "Chon File..."; key = "chonfile"; } } : row { : button { label = "Ve"; is_default = true; key = "accept"; } : button { label = "Thoat"; key = "cancel"; } } } Have a look at writing the dcl as part of the lisp code, you use write line and the (setq fo (open (setq fname (vl-filename-mktemp "" "" ".dcl")) "w")) to write a temporary file just delete the file at end of dcl use. Have a look at Multi getvals.lsp will write a dcl for you based on a list of edit boxes. Around 3 lines of code to make a dcl. You can set file name so can see the dcl code. Then use the rlx code to make lisp code. Convert dcl 2 lisp rlx.lspMulti GETVALS.lsp Edited April 16 by BIGAL 1 Quote
