I’m working on a lips to add an xref to a drawing. The filename begins with a 4 letter project designator that changes but the rest of the name is static. I’m using * as wildcards but it’s not working.
For filename I have:
(setq wildcard "****-CP-SITE-BASE.dwg") ; Define the wildcard pattern to match xref names
  (setq xrefFiles (vl-directory-files xrefPath wildcard 1)) ; Get a list of xref files matching the wildcard
  (foreach xref xrefFiles
  (setq xrefFile (strcat xrefPath wildcard))
  (command "_.-XREF" "Attach" xrefFile "0,0,0" "1" "1" "0")
When I run it, I get this error:
Error: "..\01_Basefiles\****-CP-SITE-BASE.dwg" is not a valid file name.
*Invalid*
; error: Function cancelled
I'd appreciate any help,
Thanks
Changed the code to:
(setq drawingName (getvar "DWGNAME"))
  (setq prefix (substr drawingName 1 4))
  ;; Construct the xref file path
  (setq xrefPath (strcat xrefPath prefix "-CP-SITE-BASE.dwg"))
and this seems to be working!
*Invalid*
Thanks
Hello
Replace the 4 * with ?
