import traceback
from pyrx import Rx, Ge, Gi, Gs, Db, Ap, Ed, Ax
@Ap.Command()
def mynewcommand():
    try:
        print("\nhello world!")
    except Exception as err:
        traceback.print_exception(err)
So, you’ve decided to take the red pill.
You can think of these as similar to .NET references, or name spaces. Ge = AcGe from ObjectArx, Ax = ActiveX
@Ap.Command()
Tells the system to register a new command, you can also register lisp functions, so you can use python to help extend lisp (more on that later)
Body of the function.
Command functions should have a try catch to prevent python exceptions from escaping into C++, it’s not the end of the world if it happens, but it’s advised. You don’t need to have try catches in your subroutines.
Since Python is now running in CAD’s process, I have redirected Python’s std_out to AutoCAD’s command line.
Yay! Stuff like this is forbidden lol!
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage
Just print will do
Edited by Danielm103
Next, choose your style, ARX vs AX
Ax is ActiveX, the coding style most Lisp or VB(A) users are used to. You don’t need to manage an open close state for the objects. Perfect for quick scripts
ARX style, you pass around collections of ObjectIds, in which you open objects with. In this style you may have to manage open close state. Python will help you manage this along the way. Unlike .NET,  you don’t need to use transactions, you don’t need to use a transaction to open objects then cast, there's no commit, Just pass the id and the open state. Python will do all the closing for you
import traceback
@Ap.Command()
def py_arx_vs_ax():
    try:
        # for VBA users
        axApp = Ap.Application.acadApplication()
        axDoc = axApp.activeDocument()
        axSpace = axDoc.modelSpace()
        for ent in axSpace:
            ent.setLayer("0")
        # ARX users
        cdoc = Ap.curDoc()
        db = Db.curDb()
        space = Db.BlockTableRecord(db.modelSpaceId(), Db.OpenMode.kForRead)
        for id in space:
            ent = Db.Entity(id, Db.OpenMode.kForWrite)
            ent.setLayer("0")
In Python, ent is a smart pointer, almost exactly like its C++ counterpart
AcDbEntityPointer pEnt(eid, AcDb::OpenMode::kForWrite);
ent is closed when it goes out of scope
An actual wrapper
PyDbEntity::PyDbEntity(const PyDbObjectId& id)
    : PyDbObject(openAcDbObject<AcDbEntity>(id, AcDb::OpenMode::kForRead), false)
PyDbEntity::PyDbEntity(const PyDbObjectId& id, AcDb::OpenMode mode)
    : PyDbObject(openAcDbObject<AcDbEntity>(id, mode), false)
PyDbEntity::PyDbEntity(const PyDbObjectId& id, AcDb::OpenMode mode, bool erased)
    : PyDbObject(openAcDbObject<AcDbEntity>(id, mode, erased), false)
more info
