Displaying xyz of a point?
How to use DX command? If i use the command, the save as dialog is opening...
I have to display the x,y, radius of selected objects in any format like xls, txt,doc like.
  • Replies 22
  • Tiger
    4
  • lpseifert
    3
  • gnanapaul
    3
  • colingra
    2
I have to label co ordinates quite often, and the easiest way I've found is to use DIMORDINATE, draw my northings and eastings, and then invent a new dimension style which suits your needs, ie rotates the Eastings and puts an 'E' beofre it, and puts an 'N' before the Northings, then move the dimensions using the grips. It takes a bit of time but easier than IDing all the points and typing them in manually!
I'm complete crap at macros (I could do this with Lisp w/o any trouble), but I'm sure one of the macro guys could modify this to work properly.
^C^C_ID\\-mtext $(getvar,lastpoint) W 0 $(getvar,lastpoint)
I'm not even sure if it will work. :?
Basically, it will allow the user to pick a point with ID, then place a piece of MText at the last point picked and giving it that value. It's worth a try.
