Switch/Activate to an Open Drawing - Part of a Larger Routine
My end goal is this:
From the current drawing
       Go to model space
        Copy everything using 0,0 as the base point.
Switch to a specific drawing (ie:TARGET.dwg)
       Activate model space
       Paste the clipboard to 0,0
this code does the first part
(defun c:C2C (  )
  (vl-load-com)
  (command "model") ;; Switch to model space
  (command "_.ZOOM" "EXTENTS")
  (command "_.COPYBASE" "0,0" "ALL" "")
I found the snippet below here
(vla-activate(vla-open (vla-get-documents (vlax-get-acad-object))(findfile "TARGET.DWG") ))
which will open a drawing you specify (if it is already open it opens a locked version)
I do not know how to simply switch to an already open drawing (ie:TARGET.dwg)
Once the Target drawing is open I have this
(command "model") ;;;switch to model space
(command "pasteclip" "0,0") ;;;pastes clipboard to 0,0
Tharwat posted this
(defun c:Test nil
 (vlax-for doc (vla-get-Documents (vlax-get-acad-object))
   (if (eq (vla-get-fullname doc) [color=red]<complete_path_of_opened_drawing>[/color] )
     (vla-put-windowstate doc acmax)
     (vla-put-windowstate doc acmin)
(vl-load-com)
but I could not make it work.
This is as close as I have been able to get.
(defun c:C2C2 (  )
  (vl-load-com)
Once the other drawing is open it will not process any other commands provided.
Typically I will have both the "source" and "target" drawings open at the same time
Can someone help me put these pieces together?
Edited by ILoveMadoka
  • ILoveMadoka changed the title to Switch/Activate to an Open Drawing - Part of a Larger Routine
Not possible really with LISP.
LISP is run via the parent drawing, so when you switch drawings, the 'parent' also changes - and this second isn't running the LISP, the LISP will just stop running.
You can try making a script to run a routine on one drawing and then the next, but I have only really had success where you open the drawing and not switch to an all ready opened drawing - I think it was something to do with getting the script to recognise which drawing to work on - opening the drawing then that drawing becomes the current one by default.
Anyway, generally not possible or easy (there are a few rare exceptions).
You might want to create 2 LISP files, one to do all the processing you need in drawing 1 and the other to do everything in drawing 2 - in your example:
LISP 1 Copy
LISP 2 Paste
but you have to manually switch from one to the other. You can make use of registry settings or temporary files to store information while you switch from one to the other.
(be great if it could.... been looking for something suitable to for example plot every open drawing for years and never found anything suitable, referencing Lee Mac, I think all his batch processes need all but the reference drawing to be closed)
Edited by Steven P
Hi
I don't know what CAD environment you're working in.
If you have a version of AutoCAD Map or C3D, you could use the "ade_" functions to achieve this.
Autocad 2025 Vanilla
if this opens a drawing called
how can I switch to an already open drawing called TARGET.DWG?
Generally with LISP it is not possible.
Okay.
You can still try.
I don't know what's new in the latest versions of AutoCAD.
Try typing, for example, 'ade_savetodwg' in the Visual Lisp editor to see if it recognizes it as a function.
Aladdin might emerge from inside the lamp.
And...You can also:
1) Type arx in the command line and press Enter to check if ade.arx appears in the list.
2) Search the AutoCAD directory to see if ade.arx exists.
Edited by GLAVCVS
If I cannot make this part work, it's not going to work anyway..
I run this autoloading command to copy everything from the first drawing
(defun c:C2C1 (  )
  (vl-load-com)
The SOURCE drawing is opened as well.
I have the following autoloading as well.
(defun c:C2C2 (  )
(command "model")
(command "pasteclip" 0,0)
(princ) )
If I run that command, nothing happens.
If I <CTRL> V it pastes the clipboard with my desired geometry into the drawing.
The <CTRL> V may be my workable solution but still...
if I type this at the command prompt
It works as well.
I do not understand what is wrong here
I'll look at the ade stuff tomorrow..
Wonder if there is a tchnical difference between:
and
.. looking at "'s
0,0 could be "0,0" or a list, '(0 0) or (list 0 0) in pasteclip (and better to be a list, and the same in copybase)
Found something I had, Can be a bit flaky only have 1 new dwg open.
; by alanh copy a window from another dwg
; Nov 2019
(defun openblk (blkname / adocs)
(setq acDocs (vla-get-documents (vlax-get-acad-object)))
(vla-open acDocs blkname)
(command "copyclip" "w" (getvar 'extmin) (getvar 'extmax) "")
(vla-close (vla-item acdocs 1) :vlax-false)
(openblk "d:\\acadtemp\\y.dwg")
It may be possible to play with the items in acdoc if you do a dump you will see current count of the number of dwgs open.
you might try python, concept
from pyrx import Rx, Ge, Gi, Gs, Db, Ap, Ed, Ax
import traceback
def dowblock(fromdb: Db.Database, path : str):
    lock = Ap.AutoDocLock()
    todb = fromdb.wblock(fromdb.modelSpaceId())
    todb.saveAs(path)
@Ap.Command("doit", Ap.CmdFlags.SESSION)
def woohoo():
    try:
        path = "e:\\temp\\outdwg.dwg"
        dowblock(Db.curDb(), path)
        Ap.DocManager().appContextOpenDocument(path)
        Ed.Core.alert(Ap.curDoc().fileName())
    except Exception as err:
        traceback.print_exception(err)
It's the simple things...
Solution:
(Command "Pasteclip" "0,0")
Sheesh!!
I will mess with the other code to see what they do..
Thank you all so very much!!
