Downer Posted April 22 Posted April 22 Hello, I need some help regarding Layouts to DWGs and DWGPROPS. I'm currently using the original layouts to dwg command that Bijucad09 posted. Everything runs good until I open the new drawings, and all of my DWGprop links have been removed. They are replaced with "#'s" Any insight would help. Thank you! Quote
Downer Posted April 23 Author Posted April 23 22 hours ago, Downer said: Hello, I need some help regarding Layouts to DWGs and DWGPROPS. I'm currently using the original layouts to dwg command that Bijucad09 posted. Everything runs good until I open the new drawings, and all of my DWGprop links have been removed. They are replaced with "#'s" Any insight would help. Thank you! @pkenewell Would you be able to help? Quote
Downer Posted April 24 Author Posted April 24 Hello, I am having issues with DWG Props delinking each time I use the Layouts to DWG LISP command. I'll attach the LISP command and 2 photos showing what my title block looks like before and after using Layouts to DWG. Any insight would be appreciated! Thank you! LayoutsToDwgs.lsp Quote
pkenewell Posted April 24 Posted April 24 On 4/23/2025 at 4:29 PM, Downer said: @pkenewell Would you be able to help? Sorry not at the moment - I'm way to tied up in my job to work on it. I only have time to do this when things are slow at work. 1 Quote
BIGAL Posted April 25 Posted April 25 It is more than likely as your using fields that when you copy to new dwg, all the object ID's are reset so it no longer works. Same object copied into a 2nd dwg. DWG1 object id1982696560 DWG2 object id 1295687472 Depending on how you made the fields you will have to remake again. Where I worked last, -we used text in the attributes and used fields where they read global values, like Sheet X of Y, the X & Y are fields related to layouts so work in all dwg's. 1 Quote
BIGAL Posted April 25 Posted April 25 Is this posted twice I will have to look for the other posted an answer. Please dont post twice, you make the posts confusing. Admin may fix. Quote
