install lisps, DCLs, Cuix
hello guys
does anybody know how can i install my Lisps ,DCL, Cuix files by .EXE file ?
is inno setup about it?
does anything already exist?
I like INNO, the only issue is that it generates a .EXE file
You will want to create a .bundle package and have INNO put the package in
%APPDATA%\Autodesk\ApplicationPlugins\\myapp.bundle
https://help.autodesk.com/view/OARX/2025/ENU/?guid=GUID-5E50A846-C80B-4FFD-8DD3-C20B22098008
PackageContents.xml would have an entry for your cui as well
https://help.autodesk.com/view/OARX/2025/ENU/?guid=GUID-40F5E92C-37D8-4D54-9497-CD9F0659F9BB
Doing bundles is pretty straight forward when you have an example to look at, that is for Autocad, Bricscad is different. Hence next method.
Whilst not an exe I got around it by using a install.lsp, it looks for a zip file with all your stuff in it, Yes lisp can be used to unzip to a nominated directory, part 2 is that the lisp loads custom menu,s sets support paths. So ready to go, for multiple users email the zip and lisp, save the zip somewhere and run the lisp.
Happy to provide more info.
Edited by BIGAL
I'm happy to hear about this approach. Could you please share it if you can?
Which one the Bundle or the using a ZIP.
(vl-mkdir "c:\\CAD-TOOLS")
(setq filename (getfiled "Select the File \"CAD-TOOLS-APR-2025\"" "" "ZIP" 16))
; unzip
(startapp (strcat "powershell -command Expand-Archive -Path '" filename "' -DestinationPath 'C:/CAD-TOOLS' -FORCE"))
(alert "programs unzipped to C:/CAD-TOOLS")
; load menus set support paths etc next
; unzip
bundle please🙏
This  may help.
The Xml is not critical in some of the values I just edited one I had. The web emali etc dont have to be real
<ApplicationPackage SchemaVersion="1.0" AutodeskProduct="AutoCAD" ProductType="Application" Name="XYZ" AppVersion="1.0.0" Description="Product Description" Author="AH" AppNameSpace="Alanh consulting.com.au" ProductCode=""ABCDEFG" UpgradeCode="HIJKLMN" FriendlyVersion="1.0.0" FriendlySupportedLocales="Enu" OnlineDocumentation="http://www.whoknows.com">
<CompanyDetails Name="AH" Email="info@alanh.com.au" Url="http://www.AlanH.com.au"/>
<RuntimeRequirements OS="Win32|Win64" Platform="AutoCAD*"/>
<Components Description="ANY AUTOCAD">
<RuntimeRequirements OS="Win32|Win64" Platform="AutoCAD*" SupportPath="./Contents/Resources;./Contents/Programs"/>
<ComponentEntry AppName="Name of Menu to Load" ModuleName="./Contents/Resources/Utilities.cuix" LoadOnAppearance="True" LoadOnAutoCADStartup="True"/>
<ComponentEntry AppName="Lisp File to Load" ModuleName="./Contents/Programs/Goto-layout.lsp" LoadOnAutoCADStartup="True"/>
<ComponentEntry AppName="Lisp File to Load" ModuleName="./Contents/Programs/Multi GETVALS.lsp" LoadOnAutoCADStartup="True"/>
</Components>
</ApplicationPackage>
Last comment can use the lisp method above to install the correct zip containing the bundle.
Edited by BIGAL
