Hi. I  use this lisp code to convert the form of a txt file from
this
0	299153.24	4218596.34
1	299163.21	4218607.51
2	299163.99	4218607.02
3	299176.94	4218599.90
4	299207.37	4218583.27
5	299220.70	4218575.98
6	299242.94	4218563.71
7	299253.41	4218557.75
8	299256.14	4218556.19
9	299253.94	4218553.77
10	299251.66	4218551.25
11	299248.52	4218547.79
12	299244.81	4218549.59
13	299235.68	4218554.00
14	299218.39	4218562.90
15	299197.46	4218573.57
16	299177.72	4218583.74
17	299164.10	4218590.73
18	299153.87	4218596.07
19	299153.24	4218596.34
to
299153.24,4218596.34
299163.21,4218607.51
299163.99,4218607.02
299176.94,4218599.90
299207.37,4218583.27
299220.70,4218575.98
299242.94,4218563.71
299253.41,4218557.75
299256.14,4218556.19
299253.94,4218553.77
299251.66,4218551.25
299248.52,4218547.79
299244.81,4218549.59
299235.68,4218554.00
299218.39,4218562.90
299197.46,4218573.57
299177.72,4218583.74
299164.10,4218590.73
299153.87,4218596.07
The code works fine but convert only one file a time. Is it possible to update the code to convert all *.txt files in the folder to *.pl  at once . The code I use is
    (defun c:test (/ FF FFN TXT TXTS)
      (setq ffn  (getfiled "Select file " "" "txt" 0)
            ff   (open ffn "r")
            txts nil
      (while (setq txt (read-line ff)) (setq txts (cons txt txts)))
      (close ff)
      (setq txts (mapcar '(lambda (x) (STD-STRSPLIT x "\t,; ")) (reverse txts)))
      (setq txts
             (mapcar
               '(lambda (x) (vl-remove-if '(lambda (y) (and (not (equal "0" y)) (zerop (atof y)))) x))
               txts
      (setq ff (open (strcat (substr ffn 1 (- (strlen ffn) 3)) "pl") "w"))
      (foreach item txts (write-line (strcat (cadr item) "," (caddr item)) ff))
      (close ff)
    ;;; The order of chars in delim is not important.
    ;;; keeping null tokens, not as with std-strtok.
    ;;; Might be renamed to std-string-split
    ;;; by Vladimir Nesterowsky
    (defun STD-STRSPLIT (s delims / len s1 i c lst)
      (setq delims (vl-string->list delims) ; fixed
            len    (strlen s)
            s1     ""
            i      (1+ len)
      (while (> (setq i (1- i)) 0)
        (setq c (substr s i 1))
        (if (member (ascii c) delims)
          (if (/= i len)                    ; "1,2," -> ("1" "2") and not ("1" "2" "")
            (setq lst (cons s1 lst)
                  s1  ""
          (setq s1 (strcat c s1))
      (cons s1 lst)                         ; ",1,2" -> ("" "1" "2")
I upload some txt files to test the code
Thanks
1.txt 2.txt 3.txt
Hi
You simply need to get the list of files in that directory with 'vl-directory-files' and create a loop so the code repeats for each file.
The main function, modified, could be like this:
(defun c:test (/ FF FFN TXT TXTS ab d lst rpta)
  (if (setq d (getfiled "Select file " "" "txt" 0))
      (while (not (member (setq rpta (strcase (getstring (strcat "\nConvert Only \'" (setq ab (vl-filename-base d)) ".txt\'? <Only>/All directory: ")))) '("" "O" "A")))
	(princ "\n* Invalid option * Try again (ENTER, O or A) ...")
      (if (= rpta "A")
	(setq lst (vl-directory-files (vl-filename-directory d) "*.txt"))
	(setq lst (list (strcat ab ".txt")))
      (foreach ffn lst
	(setq ff (open (setq ffn (strcat (vl-filename-directory d) "\\" ffn)) "r")
	      txts nil
	(close ff)
	(setq txts
	       (mapcar
		 '(lambda (x)
		    (vl-remove-if
		      x
		 txts
	(foreach item	txts
	(close ff)
      (startapp "explorer" (vl-filename-directory (strcat (vl-filename-directory d) "\\")))
PS:
Try it.
I haven't done it.
I try your code. Ithink it works. I will test more.
Thanks GLAVCVS
