Danielm103 Posted May 1, 2025 Posted May 1, 2025 did not want to infect the lisp thread  from pyrx import Rx, Ge, Gi, Db, Ap, Ed, Ax import traceback def exploder(btrid: Db.ObjectId): btr = Db.BlockTableRecord(btrid, Db.OpenMode.kForWrite) for _id in btr.objectIds(): dbent = Db.Entity(_id, Db.OpenMode.kForWrite) try: btr.appendAcDbEntities(dbent.explode()) dbent.erase() except: pass # eNotApplicable for explode def purge(db: Db.Database, ids): for _id in db.purge(ids): dbo = Db.DbObject(_id, Db.OpenMode.kForWrite) dbo.erase() def setProps(db: Db.Database, btrids: list[Db.ObjectId]): for btrid in btrids: btr = Db.BlockTableRecord(btrid) for _id in btr.objectIds(): dbent = Db.Entity(_id, Db.OpenMode.kForWrite) dbent.setColorIndex(0) dbent.setLinetype("Continuous") if _id.isDerivedFrom(Db.Text.desc()): dbt = Db.Text.cast(dbent) dbt.setTextStyle(db.textstyle()) if _id.isDerivedFrom(Db.MText.desc()): dbmt = Db.MText.cast(dbent) dbmt.setTextStyle(db.textstyle()) @Ap.Command() def doit(): try: btrids = [] db = Db.curDb() bt = Db.BlockTable(db.blockTableId()) for _name, _id in bt.toDict().items(): btrids.append(_id) if "*" in _name: continue exploder(_id) setProps(db, btrids) purge(db, btrids) db.saveAs("E:\\temp\\mrclean.dwg") except Exception as err: traceback.print_exception(err)  mrclean.dwg Quote
