Marcin O Posted May 23, 2025 Posted May 23, 2025 (edited) Dear forum, I wish to convert date in a format 2025-05-15 into Excel convention so amount of days since 1 January 1900 (45792). Did anyone try to solve this problem? for example this code below, but maybe there is better solution, much simpler, or by using standard format inside AutoLISP. Thanks in advance M (defun datetoexcel (y m d / days) (setq days (+ (* 365 (- y 1900)) (/ (- y 1901) 4) d)) (if (> m 1) (setq days (+ days 31))) (if (> m 2) (setq days (+ days (if (= 0 (rem y 4)) 29 28)))) (if (> m 3) (setq days (+ days 31))) (if (> m 4) (setq days (+ days 30))) (if (> m 5) (setq days (+ days 31))) (if (> m 6) (setq days (+ days 30))) (if (> m 7) (setq days (+ days 31))) (if (> m 8) (setq days (+ days 31))) (if (> m 9) (setq days (+ days 30))) (if (> m 10) (setq days (+ days 31))) (if (> m 11) (setq days (+ days 30))) (+ days 1)) Edited May 23, 2025 by Marcin O better title Quote
GLAVCVS Posted May 23, 2025 Posted May 23, 2025 (edited) Hi I haven't been able to get your code to work properly. Also, I don't think it takes leap years into account. Actually, 45,798 days have passed, but not 45,792. I have something pretty simple for this. I hope it helps. ;************************ G L A V C V S ************************* ;************************** F E C I T *************************** (defun daysFrom1900 (dia mes annvs / aa diasHAP diasB diasBs da m-1 n) (defun diasBs (ai af i / a b) (while (<= (setq a (+ ai (setq i (1+ i)))) af) (if (or (= (rem a 400) 0) (and (= (rem a 4) 0) (/= (rem a 100) 0))); (setq a 1900) (or (= (rem a 400) 0) (and (= (rem a 4) 0) (/= (rem a 100) 0))) (setq b (if b (1+ b) 1)) ) ) (if b b 0) ) (setq diasHAP (* (- annvs 1900) 365) diasB (diasBs 1900 (- annvs 1) -1) da (- (* (setq m-1 (- mes 1)) 31) (foreach x '(4 6 9 11) (if (> mes x) (setq n x) (if n n 0))));(vl-some '(lambda (x / n) (if (> m-1 x) (not (setq n (if n (1+ n) 1))) n)) '(4 6 9 11))) da (if (and (> mes 2) (or (= (rem annvs 400) 0) (and (= (rem annvs 4) 0) (/= (rem annvs 100) 0)))) (- da 2) (if (> mes 2) (- da 3) da)) ) (+ diasHAP diasB da dia) ) Edited May 24, 2025 by GLAVCVS 1 Quote
GLAVCVS Posted May 23, 2025 Posted May 23, 2025 I've only changed the function name for you. If the order of the dd/mm/yyyy arguments is a problem for you, you'll need to change them. 1 Quote
Lee Mac Posted May 23, 2025 Posted May 23, 2025 (edited) Here's another way - (defun ctoe ( y m d ) (if (not ctoj) (load "julian.lsp" nil)) (if ctoj (- (ctoj y m d 0 0 0) 2415019)) ) Edited May 24, 2025 by Lee Mac 1 Quote
Marcin O Posted May 24, 2025 Author Posted May 24, 2025 @Lee Mac many thanks for simple script - wrapper for ctoj function. I did not know there is a julian.lsp Julian calendar included in Express tools @GLAVCVS thank You for another option for calculations 1 Quote
